EOT vs ECT - Ford Powerstroke Diesel Forum
post #1 of 3 Old 08-01-2013, 06:51 PM Thread Starter
EOT vs ECT
I had a bad oil cooler and replaced it today with a new one. Here's my question. Prior to the new one, I'd see a delta in the 20 degree range. Today after the install I drove about 15 miles. ECT ran 188-192 and EOT never got over 202. Does this seem high on a brand new cooler? I'm within the 15 degress but at times it was a difference of 12 degrees. All this unloaded and 90's outside. I did flush the system and running close to a 50/50 mix of coolant/water.
txhellraiser is offline
post #2 of 3 Old 08-01-2013, 07:19 PM
its within spec... When its in the 90's you will see higher temps and splits- especially if driving down the highway at 65 mph +.
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #3 of 3 Old 08-02-2013, 06:55 PM Thread Starter
Thanks. Was just kind of concerning. I pulled the boat today and it did fine. Thanks for the reply.
