'07 6.0 rough idle - Ford Powerstroke Diesel Forum
post #1 of 5 Old 08-01-2013, 11:07 AM Thread Starter
'07 6.0 rough idle
Having a problem with the truck shuddering while idling. It'll idle for about a minute then start shuddering really bad then the pedal just goes dead. No response from it. Then the truck just dies. No warning light, not throwing any codes, nothing. Replaced both fuel filters and did and oil change. Still learning my way around diesels, and not sure what this could be. Thanks for any help guys.
kneedragger627 is offline
post #2 of 5 Old 08-01-2013, 11:22 AM
Try changing the ebp, you could have a electrical issue, can you drive the truck in that minute? Do you get the wrench light?
JorgeCanek is offline
post #3 of 5 Old 08-01-2013, 11:34 AM Thread Starter
Put it in drive, and it dies quicker. No wrench light or engine light at all while its running.
post #4 of 5 Old 08-02-2013, 04:09 PM
Do you have an EGR valve? If so, get a gasket kit from Ford ($10) and clean the valve.
'06 F250 FX4 6.0
SCJScott is offline
post #5 of 5 Old 08-02-2013, 08:10 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
Is it a rough idle when the engine is up to operating temp or only when cold? If it is only when cold I would check your FICM volts.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
