2006 6.0L No-Start after STC replacement - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-31-2013, 08:07 AM Thread Starter
Angry 2006 6.0L No-Start after STC replacement
2006 F-350, 6.0L PSD, 4x4, lariat, crew cab, long bed, with 130,000 mi.
Ok guys, I really hope you guys are able to help me here. A few months ago my STC fitting failed and cracked my rear engine cover. Since then I have replaced the STC fitting, rear engine cover, oil cooler, IRP valve, dummy plugs, oil and fuel filters, etc. After months of having it in my garage I finally got it all back together. I went to crank it, cranks good, but no start.... boo.
I do have a P0677 code (glow plug #7) could that cause a no start issue? Since I did the fuel filters I suspected a fuel problem as well. I checked the engine compartment fuel filter bowl and it did have fuel in it.
My other issue is that I do not have a computer. I'm thinking about getting the Banks iQ with the tow programmer. I want to get this one for monitoring my engine while driving and because it can do a lot of different things, but i'm not sure if it can do all of the diagnostic stuff that I need it to do right now. I've heard a lot about the SCT and might consider that one. I do have a nice Blue Point multimeter thought. hopefully the meter will be enough to get me started right now though.
If anybody could point me in the right direction on how to start tracking down this no start issue I would greatly appreciate it. I'm ready to have my truck back on the road. Thanks PS.O
Thanks PS.O community,
Stay S.A.F.E
S.A.F.E is offline
post #2 of 10 Old 07-31-2013, 08:13 AM
Can you get compressed air in your icp sensor, the fitting in the HPO rail passenger side?
JorgeCanek is offline
post #3 of 10 Old 07-31-2013, 09:29 AM
jtaylor75's Avatar
if you've had the truck torn down that much, then its going to take for ever to start. Throw a battery charger on it and keep trying.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #4 of 10 Old 07-31-2013, 09:50 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
^^^ I agree you need to crank for at least 15 seconds rest for 90 seconds then continue the cycle because you need build pressure. Put a charger on her and keep trying you get her fired.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #5 of 10 Old 07-31-2013, 10:36 AM Thread Starter
Boy I hope it's that easy. I have to run to work now, but I'll put a charger on before I go and try it when I get home tonight. This may be a stupid question but does it matter whether I charge the auxiliary battery or the Driver's-side battery? I assume they will just equalize each other.
Thanks for your help guys.
Stay S.A.F.E
S.A.F.E is offline
post #6 of 10 Old 07-31-2013, 10:43 AM
I do not think it matters just put on a 10 amp charge and it should be ok, at least that is what I did. Keep cranking just make sure to rest 90 seconds to let the starter cool off but you need to crank for at least 15 seconds. If everything is right she will fire.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #7 of 10 Old 07-31-2013, 11:48 AM
If you want to purge your Hpop system, take out the icp, put your finger on it and crack it, the air will come out and you will feel the oil pressure comming up
post #8 of 10 Old 08-01-2013, 08:17 AM Thread Starter
Talking
Well guys, went out this morning and cranked for 15 sec. on, 90 sec rest. Fired right up on the third try. I didn't even have to purge the hpo system. Thank you so much for the help guys. I'm glad it was a simple solution.... After I got the whole engine torn down and rebuilt that is. Anyway thanks again guys.
Stay S.A.F.E
S.A.F.E is offline
post #9 of 10 Old 08-01-2013, 08:34 AM
Sweet, glad to hear.
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
post #10 of 10 Old 08-01-2013, 11:18 AM
Great, another happy 6.0 aka devil costumer
Tags
6.0 , no start , sct , stc
