6.0 wont rev past 3000 rpm blowing white smoke runs rough no power wtf - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-30-2013, 08:38 PM Thread Starter
Angry 6.0 wont rev past 3000 rpm blowing white smoke runs rough no power wtf
I have a 04 350 I have had it 3 years now but now the past year I ain't had nothing but trouble. I have had to the steelership twice now. I spent over $4000 now and its still not fixed. It's still blowing white smoke has no power and won't Rev past 3000 rpms. The dealers replaced a IPC two injecters EGR flush and a map any help would be great thanks
$4000 wtf
drifincountryrebel is offline
post #2 of 3 Old 07-31-2013, 03:00 AM
I'd bet a paycheck that you've got a busted egr cooler. Do a good coolant system flush, delete your egr, and change your oil cooler.
You could have blown head gaskets since you've been driving the truck while it was sucking coolant.
Moto2four is offline
post #3 of 3 Old 07-31-2013, 04:40 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
The white smoke can only be 2 things, fuel or coolant. As suggested, if it is the EGR cooler you can delete it, but you can also park nose low and pull the EGR valve to see if there is coolant (not moisture from sitting) in the intake manifold and you should have noticed the coolant level dropping, sometimes slowly. This is easy to do even if you only own a small socket set!
If it is fuel, the FICM firing incorrectly can dump raw fuel into the cylinder that will come out the exhaust as white smoke. It could also be an injector (usually black smoke but could be white) or even an exhaust valve not closing. Revving the piss out of an engine with a problem won't fix it and it can make it worse. Take the time to methodically work through the problems I have suggested. Get a solid diagnosis from a different shop or, if you are capable and willing, get a diagnostic tool and try to trouble-shoot it yourself.
So what did they tell you was done? A trained mechanic, using IDS, should have found the problem without it breaking the bank. You need to itemize what the $4k was. If it was one injector on both heads, the bill would be significant, but I don't think any dealership could present a bill that high for what you said was done, but as we all find out, anything is possible.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
