idles fine but dies when in gear - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-30-2013, 09:45 AM Thread Starter
I have a 2004 f350 sbcc with the 6.0 and an automatic. It will crank up and run great while in park at an idle but as soon as I put it in gear it shutters and dies. I don't know what's wrong.
mgdwj is offline
post #2 of 5 Old 07-30-2013, 10:15 AM Thread Starter
all stock except for the blue spring upgrade. filters are less than 1 month old. I had a superchips 1805 programmed to it. i have since returned to stock and same thing. downloading the superchips software now try and see some real time engine data. i dont know what good it will do for me to see live engine data i dont have a fraking clue what most of it means. i did pull the codes. it is throwing 6 soft codes all for egr related stuff. i have the valve unplugged so i figure thats why i am getting them.
I am about to try changing filters. hopefully that fixes the problem, but with my luck it wont.
mgdwj is offline
post #3 of 5 Old 07-30-2013, 10:48 AM
Bad tranny?
JorgeCanek is offline
post #4 of 5 Old 08-01-2013, 04:58 AM Thread Starter
I ended up having to taking it to the stealership. Hopefully it won't be tooooo expensive.
mgdwj is offline
post #5 of 5 Old 08-08-2013, 01:14 PM Thread Starter
finally got the call from the stealership....
torque convertor is bad. suggest replace transmission, trans filter, and trans cooler.
any one know of a tranny shop that does quality work
mgdwj is offline
