2007 f250 6.0 Harley edition runs ruff when cold no power after 15-30 min of idling - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-29-2013, 01:29 PM Thread Starter
Exclamation 2007 f250 6.0 Harley edition runs ruff when cold no power after 15-30 min of idling
I have a 07 f250 6.0 I'm having power issues with if I start it up when it's cold and let the truck warm up for 15-30 min will barley shift and get up to 40 it does billed boost and feels like it has a miss in it I have changed the fuel filters and drained water separator and fresh oil with 15w40 rotella any ideas what it can be ?
Fordfreak1992 is offline
post #2 of 8 Old 07-30-2013, 06:40 PM
05f250harley's Avatar
Have you checked your FICM voltage or it could be stiction in your injectors. I had stiction and I changed to Rotella T6 5w40 and it helped alot with cold starts.
05 Harley Davison Edition Arp head studs, SCT livewire TS, 03 turbo, PMM egr delete, PMM coolant filter, afe cai, blue spring, 6.4 banjo bolts, updated stc, standpipes and dummy plugs, 4" exhaust with no cat and no muffler
03 RCSB 205/100 warren injectors, BW s366, Lots of supporting mods to come
05f250harley is offline
post #3 of 8 Old 07-30-2013, 07:11 PM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
Agreed^^ check ficm voltage, do you have a monitor? Any codes? Egr valve? If so clean egr valve, check codes, and ficm voltage.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #4 of 8 Old 07-30-2013, 07:23 PM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
Welp, those guys beat me to it
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #5 of 8 Old 07-30-2013, 07:24 PM
Powerstroke Techie
Quoted: 13 Post(s)
Garage
ficm, injectors or both
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #6 of 8 Old 07-30-2013, 07:57 PM Thread Starter
Smile
What's the correct way to check the ficm ? And
post #7 of 8 Old 07-30-2013, 07:58 PM Thread Starter
Also no codes are present at this time
post #8 of 8 Old 07-30-2013, 08:09 PM
What did you use to check for codes?
I found this for checking ficm voltage.
http://www.ficmfixer.com/testing.htm
-Steven
Sold!!
Studs
Egr delete
S&b intake
php 140x
PHP Atlas 80
My baby-
87 jeep wrangler
On 33s
Tags
2007 f250 , 6.0 advice , 6.0 cold starting , 6.0 running bad , cold starting
