6.0 stuttering/missing - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-28-2013, 08:51 AM Thread Starter
6.0kansaspowerstroke's Avatar
Angry 6.0 stuttering/missing
I have an 04 6.0 with 110k on the clock. Just replaced the oil cooler. Everything came apart and went back together fine. started it up and ran fine idling. Drove for a couple days with no problems. Then this started. At about 50+ mph the truck seems to have a miss/stutter. Hot or cold doesnt matter. Ive had problems with stiction before but that only did it when oil was cold. Rev-x helped that problem. It does it on acceleration also. Turbo is boosting fine. I cleaned it while I had it out. I checked all plug ins and everything looks good. Im getting a p0405,p1000,p2290 codes. I know the p0405 is egr since its deleted. The p1000 i have no idea about. The p2290 is icp.
The icp code i can clear and it might not come back for a couple days. The truck still has the problem when code is cleared. Can a failing icp cause a miss/stutter? Truck starts fine hot or cold. I dont have funds to replace injectors so im hoping its the icp. Please help!
04 f-250 crew cab xlt
5 inch turbo back
zoodad mod
foil delete
egr? what egr? O that thing i threw it in the recycling bin. See im still green
full bumper replacement
head studs coming soon
ride rite bags and flip over ball
hankook mt's 285's
SCT X3
custom tuned by innovative
edge insight cs
sinister coolant filter
blue spring mod
6.0kansaspowerstroke is offline
post #2 of 12 Old 07-28-2013, 09:29 AM Thread Starter
when reving it in park at about 2k rpm it starts cutting out and sounding like its missing. The icp voltage is anywhere from 1.9-3.6 ish.
5 inch turbo back
zoodad mod
foil delete
hankook mt's 285's
SCT X3
edge insight cs
blue spring mod
post #3 of 12 Old 07-28-2013, 12:03 PM Thread Starter
5 inch turbo back
zoodad mod
foil delete
hankook mt's 285's
SCT X3
edge insight cs
blue spring mod
post #4 of 12 Old 07-28-2013, 12:13 PM
Lastcaveman's Avatar
Quoted: 5 Post(s)
I hope you get an answer as I`m having the same problems as you.
Lastcaveman is offline
post #5 of 12 Old 07-28-2013, 12:26 PM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 888 Post(s)
Feedback Score: 6 reviews
Usually the ICP would cause the truck to die when warm and not want to start. Not quite sure it's your ICP.
I will pass this thread on to a good tech here and see what he has to say.
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is online now
post #6 of 12 Old 07-28-2013, 01:31 PM
gotta_gofast's Avatar
Quoted: 60 Post(s)
My truck would stumble with no load (like high idle 1200rpm). FICM checked out fine, ICP was good, so I ran a cylinder contribution test and found cylinder 2 to be weak. Ended up being a fuel injector so I just sent out all 8 to be rebuilt and bumped up to 155. If the ICP is good and you are sure your FICM is fine it is most likely an injector. However, low fuel pressure and dirty filters can cause similar symptoms.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #7 of 12 Old 07-28-2013, 02:10 PM
04cr450's Avatar
sounds like the famous fuel injector failure to me..
Late 04 f350 lariat.
bpd
marty's regulated return
205/75 injects from holder's
WPE stage 3 ported intake
64.5 borg warner fmw ,compounds in the works now! Comp turbo set up
Warren comp trans
all the typical mods
Big thanks to Dale! The man is a true professional
04cr450 is offline
post #8 of 12 Old 07-28-2013, 03:23 PM Thread Starter
Thanks rattlesnake18
Fuel filters were done about 1000 miles ago. Im not ruling that completly out.
I unplugged the icp sensor and started it up and went for a drive. No stutter at any point in the rpm range. Did lack power and would only build about 20 pounds of boost. Guessing cause its only reading default info.
Stopped and plugged it back in and still no stutter. Power was back boost was back ran like it was supposed too. Is the sensor the culprit? Im hoping it is cause thats alot cheaper than a set of injectors. Its driving me mad.
5 inch turbo back
zoodad mod
foil delete
hankook mt's 285's
SCT X3
edge insight cs
blue spring mod
post #9 of 12 Old 07-29-2013, 03:09 PM Thread Starter
5 inch turbo back
zoodad mod
foil delete
hankook mt's 285's
SCT X3
edge insight cs
blue spring mod
post #10 of 12 Old 07-30-2013, 05:41 AM
I can tell you from personal experience that, at least on an '04 model, if you run it with the icp sensor unplugged, plugging it back in while the engine is running does not cause it to start using data from that sensor again. You must shut it off and restart it, then it'll use sensor data. I know this because I recently fixed a truck with a bad icp sensor. What happened was that unplugging the sensor caused the truck to immediately run right (minus some power, as you described) and watching the sensor values on my scan tool I could see that it started using default values when I unplugged it. Plugging it back in while running did NOT cause the symptoms of the bad sensor to return. As you would expect, it also still showed default values for that sensor. Shutting the truck off and restarting it with the sensor now plugged in DID cause it to go haywire, with the accompanying crazy sensor values.
So, my point in all that rambling is that if you are plugging the sensor back in while it's still running, you are not actually causing the ecm to start using that sensor again-it's still running off the default table until you do a shut off/restart.
Edit: I may have misread your post a couple up from this one to mean that you plugged it back in while it was running. If so, disregard all my drivel.
v8440 is offline
