2003 f350 help!!!!!!!!!! - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-27-2013, 09:32 AM Thread Starter
I have a 03 f350 that died on me yesterday it would restart but only stay running for a sec or two. After a few times of that happen it will not restart at all towed to the house were I let sit for few hours went to scan it an thought what the hell ill try an start it. It started twice but only ran for a sec or two. Put scanner on it ficm is 48 icp is only 120 when cranking. So has lowww oil pressure. Thought to my self could be hpop but would it restart if pump was bad? I just got done with head studs egr delete turbo updates fuel pressure up date new Stan pipes. It does have the messed up oil rails where u have a line connecting from rail to Stan pipes. Any help plz
Stroken150 is offline
post #2 of 13 Old 07-27-2013, 09:45 AM Thread Starter
For got to mention it does have new oil cooler. An it does not have any check eng lights other then the egr code cuz it's removed
post #3 of 13 Old 07-27-2013, 01:56 PM
Powerstroke Techie
Quoted: 16 Post(s)
Garage
Feedback Score: 4 reviews
do you have any way to pull the IPR and inspect the screen? If you just replaced the oil cooler its possible some debris got into the oil reservoir and made it's way to the IPR.
Also the ICP sensor has a high failure rate on the 03s, I would look there too for a leaking sensor
-Matt
Ford Senior Master Tech
2015 F-250 XLT 6.7L
2006 F-250 6.0L SOLD
sinner6.0L is offline
post #4 of 13 Old 07-27-2013, 04:15 PM
Just put a manomrter in the icp, is that hard?
That way you can read the HPOP pressure, id you dont have LPOP pressure you are goingo to have 0, or else the IPR is broken
JorgeCanek is offline
post #5 of 13 Old 07-27-2013, 09:52 PM Thread Starter
Icp pressure was 120 when cranking an when I did all the updates an studs I put a new screen kit on ipr valve. But will take back off to see maybe it fell off
post #6 of 13 Old 07-28-2013, 03:49 AM
Check the easy stuff first, take the IPR valve off, and che,k it with some fuel
post #7 of 13 Old 07-28-2013, 04:26 AM
kdogg85's Avatar
For sure look at your ipr%. If its at 84 or so percent, the screen has trash or the hpop has died. Iirc, 03 and early 04 are known for the hpops going bad kind of early.
David
05 f250 ( double your pleasure ) underway
'10 f250 ccsb 4x4, project super mom 366/515 compounds, 200hp sticks, and all the other goodies
Most importantly, the car seat mod
kdogg85 is offline
post #8 of 13 Old 07-29-2013, 07:50 PM Thread Starter
Plan on it this week. Only thing that gets me is I'm not even getting oil to oil filter an yes I'm pressing the check ball down. So it makes me think it may be the low pressure oil pump? Any thoughts
post #9 of 13 Old 07-30-2013, 04:05 AM
Maybe the plug on the front cover, below the low pressure oil pump went bad. You should look for damages on your LPOP, the regulator plug, or the piping in the oil pan, 2003 has a failure with those
post #10 of 13 Old 08-02-2013, 11:45 AM Thread Starter
just replaced the lpop and inspected plug and spring on front cover and still no low oil pressure. starting to tick me off lol
