Loosing coolant - Ford Powerstroke Diesel Forum
post #1 of 20 Old 07-26-2013, 10:45 PM Thread Starter
05f250harley's Avatar
Loosing coolant
I had my truck studded around February of this year. My head gaskets were not leaking when i had it studded. I'm loosing coolant and can't find a leak any where. I thought I had a crack in my degas bottle so I replaced it and I'm still loosing coolant. Its not puking out of the degas bottle. Is there any thing it could be other than blown head gaskets or a cracked head?
05 Harley Davison Edition Arp head studs, SCT livewire TS, 03 turbo, PMM egr delete, PMM coolant filter, afe cai, blue spring, 6.4 banjo bolts, updated stc, standpipes and dummy plugs, 4" exhaust with no cat and no muffler
03 RCSB 205/100 warren injectors, BW s366, Lots of supporting mods to come
05f250harley is offline
post #2 of 20 Old 07-27-2013, 12:28 AM
When testing are you duplicateing the conditions as close as possible to when the event occurs. I mean if your leak only shows up after running for 3 hours testing after running only 20 minutes may not show you anything
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 20 Old 07-27-2013, 02:08 AM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 486 Post(s)
Garage
Its possible to have a leaking egr cooler. Do you have any way to check the cooling system pressure?
You can put a gauge in the coolant filter at the extra outlet that has a plug in it.
I have one in mine and have noticed the pressure coming up over time. I am going to change out the gauge with a new one, hoping the heat has taken its toll on the borden tube softening it up and getting higher readings then it should be.
Used to see 4-5 psi and lately its up around 12-13 psi.
You have it going somewhere though and the egr cooler is a likely spot.
You can pull the egr valve and look in manifold and see if there is moisture in there. If so its most likely the cooler.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
2000 Watts of McIntosh Bliss
mhatlen is offline
post #4 of 20 Old 07-27-2013, 02:57 AM Thread Starter
Forgot to mention I don't have an egr cooler
post #5 of 20 Old 07-27-2013, 03:32 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
I know you say you can't find a leak, but the most common place is where the hose coming from your oil cooler attaches to your EGR delete. Check those clamps. If that is ok, get a coolant pressure tester and pump the system to 15-17 psi and start watching and listening. Park on a dry area.
dhanna6powerstroke is offline
post #6 of 20 Old 07-27-2013, 06:10 PM
BlackSheep5's Avatar
Water pump is prob leaking but not enough that its going to make a puddle. Look at the water pump with a long handled mirror and check for crusty dried coolant around the bottom of it.
Sent from AutoGuide.com App
08 F250 6.4L FX4
BlackSheep5 is offline
post #7 of 20 Old 07-28-2013, 06:20 PM Thread Starter
i parked it last night on a concrete drive way and when i went to go leave this morning there was a big puddle of coolant. it was on the passanger side dripping from the same area that it drips from the a/c. I drove from atlanta ga back to greensboro nc today and i stopped in columbia and noticed that i had puked out the degas bottle.
post #8 of 20 Old 07-28-2013, 06:25 PM
ngaraiderman's Avatar
Need to test coolant pressure. With it puking it sounds like it may be the HG's. Did they do the heads correctly when you had the truck studded or did they just throw them back on with new gaskets and studs?! What kind of HG's did they use? Not sounding good to me
ngaraiderman is offline
post #9 of 20 Old 07-28-2013, 06:46 PM Thread Starter
coolant problems
I have been meaning to check the pressure but havent had time to mess with it. When it was studded they used oem gaskets and sent the heads off to be checked.
Sent from AutoGuide.com Free App[/QUOTE]
post #10 of 20 Old 07-30-2013, 05:42 PM Thread Starter
It hasnt puked any more. I think my cap was loose. I have been to several parts stores and cant find a low pressure gauge. Were can i get one?
