Need Help please think my injector or injectors crapped out ?? - Ford Powerstroke Diesel Forum
post #1 of 28 Old 07-26-2013, 06:59 PM Thread Starter
Davepnola's Avatar
Need Help Motor is locked up , how to drain cylinders ??
2003 Excursion 6.0 went to put fuel in fuel light was on ,,, put a 100.00 worth of when I started after refueling,,,, I noticed the engine missing , no noise , no check engine light ,,,, but puffing black smoke a little ...enough to watch it on the side mirror ,,, So I drove to closest auto part store added some diesel cleaning additive ... Drove another 60 miles , I was out of town ,,, and I noticed the smoke getting more and more , especially going up hills under a load.....than I started hearing the banging noise , it would come and go , louder ,, and quitter when I pushed more on the gas pedal , and the smoke started really pouring out,,, by the time I go off of the interstate,,, the engine was really shaking and smoking bad ,,,, black cloud of smoke ... so I parked it , scanned it ,, no code ,,, I emptied the fuel tank,,, and will be installing a new filter and new diesel tom,,,, but I am thinking I have a major problem....
Does this sound like my injector or injectors failed .... this truck ran flawlessly before this last fuel up.....
and can someone help me diagnose my problem thanks
Davepnola is offline
post #2 of 28 Old 07-26-2013, 07:10 PM
Smoke was my first sign of a failed injector...lots of it. BUT, I didn't have a banging noise.
AvengerMom is offline
post #3 of 28 Old 07-26-2013, 08:14 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
You were on fumes when you fuelled up. Drain your low point/water plug. Changing your filters is a must. Was there water in the fuel after you drained it?
You may have damaged a nozzle, assuming it isn't another non-related issue. You may have to pull the injectors to trace down the banging, unless it was misfire related.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 28 Old 07-26-2013, 08:49 PM Thread Starter
Davepnola's Avatar
I was on fumes I will do this tom draining , replacing filter , But when I pulled in my driveway its was pouring smoke out, running rough , and banging loud .... is the lower water drain bolt on the filter housing ? I did not see water in fuel ..... thanks
post #5 of 28 Old 07-27-2013, 03:48 AM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
Could have an EGR valve stuck also which would explain the black smoke.
dhanna6powerstroke is offline
post #6 of 28 Old 07-27-2013, 06:17 AM
Quoted: 47 Post(s)
It is the hex plug on the HFCM.
It could be anything. This is the type of issue that, as Murphy said, will show up as an unrelated problem to muddy the water when trying to figure out what just happened.
Frank
Working for Toys
post #7 of 28 Old 08-02-2013, 12:37 PM Thread Starter
Davepnola's Avatar
Ok EGR was stuck but motor is locked up and been sitting for a week now , I have radiator out and fan and shroud,,,, how can I drain the cylinders I can't see the glow plugs ???
post #8 of 28 Old 08-02-2013, 06:43 PM
Mod Newbie
Quoted: 20 Post(s)
Glow plugs are right above the exhaust manifolds. There is a wiring harness for each side. The harness has to be removed to get to plugs.
post #9 of 28 Old 08-02-2013, 06:58 PM
DieselnDrums's Avatar
Draining the cylinders? Never heard this before. So does this mean your head gaskets blew?
06 f350, 6.0, 5 torqshift, egr delete, replaced oil cooler, SCT tuner, Head studs, MTW St 1 billet wheel, Custom tunes from GH.
DieselnDrums is offline
post #10 of 28 Old 08-03-2013, 02:44 AM Thread Starter
Davepnola's Avatar
dont know all I know is motor is locked up ... and before I shut it off it looked like the Iraquis oil wells burning .......
