"hot start" issues '06 6.0 turbo - Ford Powerstroke Diesel Forum
post #1 of 8 Old 07-24-2013, 02:47 PM Thread Starter
Exclamation "hot start" issues '06 6.0 turbo
I just bought my truck a year ago. It had 92,000 miles on it, I just hit the 100,000 mile marker. Now I'm having the "hot start" issues, I'm new to diesels so I don't understand all the acronyms yet that everyone is putting in all the threads. So, I'm wondering where to even start to fix my issue!
Should I just take it to a mechanic or dealership?
Beefy6.0Turbo is offline
post #2 of 8 Old 07-24-2013, 03:05 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
You most likely have an High Pressure Oil (HPO) leak causing the issue. Biggest problem area for the 05-07 engines is the Snap To Connect (STC) fitting on the High Pressure Oil Pump (HPOP) or the dummy plugs or stand pipes that feed oil to the oil rail under the valve covers.
dhanna6powerstroke is offline
post #3 of 8 Old 07-24-2013, 04:10 PM Thread Starter
Is this something I can change myself?
post #4 of 8 Old 07-24-2013, 05:35 PM
Mod Newbie
Quoted: 20 Post(s)
You can do it, but you need to verify the problem first. It's not a quick fix.
post #5 of 8 Old 07-24-2013, 06:16 PM Thread Starter
Do I have to see a mechanic or someone to diagnose it or is there anything I can do to figure out what the problem is?
post #6 of 8 Old 07-24-2013, 06:20 PM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
I am fighting through the exact same issues on my 04. My advice would be to take it in and have the system pressure tested so you know where the leak is, otherwise you are just replacing part randomly.
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #7 of 8 Old 07-24-2013, 06:27 PM Thread Starter
Thank you guys I'll report back as soon I find out something. Hopefully its nothing major!!
post #8 of 8 Old 07-24-2013, 06:45 PM
Mod Newbie
Quoted: 20 Post(s)
At least you don't have to worry about the STC. Stand pipes are not real common on yours either. At any rate, hope you both get it figured out soon.
