Returning p0470 code after ebp replacement - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-23-2013, 04:58 PM Thread Starter
I have an 04 250 and about 8 months ago started getting a p0470 code. I would clear it and it would come back, sometimes in a day other times it would take a week. I eventually replaced the ebp sensor and the code did not comeback for a couple months. It has started coming back and again when I clear it, it comes back after different amounts of time. I have looked on the forums a lot but can't seem to find anything with my exact problem. I live in so cal so I know it is not the cold weather issues that some have had. Any in sight would help as I really don't want to go to the dealer and spend an unknown amount of money. Ps the truck seems to run just fine.
dragon250 is offline
post #2 of 12 Old 07-23-2013, 05:22 PM
KCCO!!
kells17's Avatar
What's your rig so we can help you out better. Sounds like the tube from the exhaust manifold to the sensor may be plugged with soot since you've already replaced the sensor.
2004 F-250 Lariat CCSB
Studded, Deleted, Cold Air, Fog Light Mod,
IPR HF Coolant Filter, High Idle, Atlas 40 FICM,
CCV, Edge Insight CTS, ZooDad, BPD Oil Cooler,
4" Banks Monster Exhaust, Fumotos, 05 Harley Headlights,
Blue Spring, Kill Switch, 03 Turbo and 6.4 Banjo Bolts
VA Strokers
757 Diesel
kells17 is offline
post #3 of 12 Old 07-23-2013, 09:11 PM Thread Starter
The truck is an 04 250 w/5r110 auto 4x4 w/170k, the only mods are 4" exhaust, bulletproof egr and oil cooler. I did take the tube off prior to replacing the sensor and it was actually really clean but I still sprayed it with cleaner and ran some pipe cleaner through it until they were going through and coming out clean. What about a map sensor issue causing this code? I'm I actually looking at something that may not be causing the problem?
post #4 of 12 Old 07-23-2013, 09:57 PM
KCCO!!
kells17's Avatar
Shouldn't be unless MAP/BARO/EBP are different at KOEO. They should all run the same. When you fire her up MAP and EBP should rise a bit. If there is no noticeable difference in how she runs, give her a day or two and see if it clears after a couple of key cycles. Hopefully someone else can chime and help...
Just re-read your initial post..key cycling obviously is a no go...maybe the sensor has gone bad again? Or a small hole in the tube?
VA Strokers
757 Diesel
kells17 is offline
post #5 of 12 Old 07-23-2013, 10:32 PM
KCCO!!
kells17's Avatar
You could check your MAP sensor hose and connection for cracks, poor connection and/or damage. The only other thing that I could think to check would be possibly your turbo boots. Make sure they are not cracked or damaged, how do your boost numbers look?
VA Strokers
757 Diesel
kells17 is offline
post #6 of 12 Old 07-23-2013, 10:41 PM Thread Starter
I'm limited in what I know because it is so stock so I don't have a boost gauge or any good scanner. I only have a simple scanner to read the codes but nothing that moniters any of the sensors. I will check the boots but it doesn't really feel like it drives much different then it did before the issue started (well I least that I can remember since its been so long) I do tow a 27 ft toy hauler with it and it does it with no problem so it doesn't seem like its lacking much power if any.
post #7 of 12 Old 07-23-2013, 10:54 PM
KCCO!!
kells17's Avatar
Check your boots, map sensor hose and connection and get back to us...have you checked the tube for build up lately? Egr valve clean? I'm running out of thoughts..
VA Strokers
757 Diesel
kells17 is offline
post #8 of 12 Old 07-23-2013, 10:57 PM Thread Starter
I haven't checked the egr but I will check the boots and map tomorrow and let you know. I appreciate the insight and hope I can get this thing taken care of finally.
post #9 of 12 Old 07-23-2013, 11:02 PM
KCCO!!
kells17's Avatar
No worries, we will get her happy!
VA Strokers
757 Diesel
kells17 is offline
post #10 of 12 Old 07-24-2013, 04:32 PM Thread Starter
Ok so its been an interesting day.
First thing in the morning I checked the map hose and turbo boots and all clamps and everything seemed to be ok. I pulled the ebp sensor out and just blew it out with my mouth not a compressor and put everything back, cleared the code and started the waiting game. Been driving the truck around all day and have not had the code come back (which by itself doesn't tell me much as it is inconsistant anyway). There is one difference this time after clearing it compared to normal. Even though I thought the truck was running fine with the code I now believe it was not spooling up because when I drove it today and got on it when it would get between 3000-3500 rpm the turbo started farting and the truck chugging and blowing black smoke. Remember there is no tuner so the truck has never smoked. It did that like 3-4 times in a row then I was where I needed to be. I kept thinking about it and figured there was a leak somewhere that was giving me the p0470 code and then while checking everything earlier I fixed that problem so now the computer was letting the turbo spool correctly to full boost but now that it is the turbo may need a rebuild. Well when I got back in the truck to come home I got on it again and everytime all the way home it excelerated smooth all the way until the shift point and did not smoke at all. So my theory is that since it had been so long since the turbo was allowed to spool it had gotten clogged up and after getting on it a few times it blew the build up out and now should be ok. Does this sound feasable or am I in left field just hoping it was that simple after all this time?
