driver side plastic CAC/ Intercooler tube on blowing off - Ford Powerstroke Diesel Forum
post #1 of 14 Old 07-21-2013, 05:13 PM Thread Starter
mudmaster's Avatar
Quoted: 12 Post(s)
I have the metal one to replace the plastic one with and Riff Raff boots to put on. Is the plastic tube my only issue or is it something more serious??
Thanks
2004 F350 FX4 6.0 60,300 miles
Banks air intake, Rubicon Express 2.5" leveling kit, 325/65X18 Goodyear Duratracs on 18X9 Metal Mulisha wheels, Dieselsite coolant filter, ScanGauge II, Steel Cold Side Intercooler Tube, Mishimoto boots, 08-12 side mirrors, billet grill, BPD's oil fill cap and oil and filter caps, EGR delete, Autometer fuel press, trans temp and EGT pillar gauges, Solid front diff cover, 08 rear diff cover, Mishimoto intercooler, more to come.............
mudmaster is offline
post #2 of 14 Old 07-22-2013, 04:52 AM
Quoted: 58 Post(s)
The plastic tubes suck. Order one of the metal ones that came with the 03/04 trucks. BPD sells them also.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDCV Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Radius Arms
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 14 Old 07-22-2013, 05:44 AM Thread Starter
mudmaster's Avatar
Quoted: 12 Post(s)
I already have it and plan to install it, just wondering if there could be another issue besides the plastic tube??
post #4 of 14 Old 07-22-2013, 05:57 AM
Quoted: 58 Post(s)
I seriously doubt it. The plastic tube gets weak and stretches do to heating and cooling, and then allows the oil residue in the CAC system to leak past the connection points. It then wont maintain the connection to the intake elbow under medium to high boost. Very common issue.
Carli Radius Arms
Carli Track Bar
Previous:
All the BPD goodies
skanj0 is offline
post #5 of 14 Old 07-22-2013, 05:58 AM Thread Starter
mudmaster's Avatar
Quoted: 12 Post(s)
Thank you!!
post #6 of 14 Old 07-22-2013, 06:01 AM
twoicebergs's Avatar
Quoted: 46 Post(s)
That depends where it is blowing off. If you are missing the steel retaining clip, it is likely it will blow off. Same goes for one that has been over-heated and stretched on a previous installation. Most change the plastic one out for the "cool" factor, but it is more susceptible to damage and breaking, especially on higher boost pressure system. I am still running my plastic one without problems.
Does your Banks intake elbow have the notch like the OEM elbow?
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #7 of 14 Old 07-22-2013, 06:08 AM Thread Starter
mudmaster's Avatar
Quoted: 12 Post(s)
It's blowing off where it meets up top where it clamps to the aluminum tube. It still has the clamp on it. It hasn't ever blown off before this.
post #8 of 14 Old 08-26-2013, 08:51 AM Thread Starter
mudmaster's Avatar
Quoted: 12 Post(s)
Yesterday it just blew again on the cold side lower boot. I've got the steel tube and Riff Raff boots installed. WTF!! Maybe I didn't get the clamp tight enough??
post #9 of 14 Old 08-27-2013, 11:08 AM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Use hair spray to help hold the boot on, plus it helps slide it on while the hairspray is still wet.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #10 of 14 Old 08-27-2013, 11:17 AM Thread Starter
mudmaster's Avatar
Quoted: 12 Post(s)
I put it back on and will give it hell towing a trailer (only about 2K) on Friday. If it blows again I'll try hairspray.
