2003 6.0 stalls,no power, won't start..help! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-20-2013, 07:06 PM Thread Starter
New to me 03 f350 with 6.0 ran fine.... Then started bogging down .. Could not get above 1500 rpm.within 1 mile it stalled and would not restart. I pulled it back to the garage and changed the fuel filters. Motorcraft used. ..started...but only idled for 3 min then stalled. Will crank over but not start. Several times it started to chug but never really took off. If I let it set for 3-4 hours it will start only to not rev above 1500 rpm and stall in 3-5 min. Ficm voltage is 46 volts. No engine codes. Battery voltage is good. Fuel pump pumps fine to the upper fuel filter, no bubbles. Any ideas what else I should check? New to diesels but learning fast.....help!thanks!
Snowman610 is offline
post #2 of 5 Old 07-20-2013, 08:02 PM
ADMIN AND TECH
SCUFFY828's Avatar
Get codes out of it. First. May help pinpointing issue. Sounds like an oil pressure issue
ITS STOCK
SCUFFY828 is offline
post #3 of 5 Old 07-20-2013, 08:04 PM Thread Starter
No codes.... Also dealer just replaced faulty water pump(was dripping) belt and did oil change.
post #4 of 5 Old 08-05-2013, 10:26 AM
My 2003 7.3L F350 is having the same issue. I just got an ICP sensor today and I am going to try replacing that. Also read that it might be the TPS. Let me know if you get yours fixed and I will do the same.
joeboggs1234 is offline
post #5 of 5 Old 08-05-2013, 03:25 PM
Replaced the ICP and did not fix. On to the next sensor.
