young pup needs help..... - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-18-2013, 10:10 PM Thread Starter
Loosing my mind so I got to rant to feel better so I apologize for the book im about to write. Let me start by saying ive have followed these forums for a while and was never a member until now and want to thank anybody and everybody for posting information. It has been a game changer in situations. Any ways I just got out of the Marine Corps a couple a months ago and just bought my first 6.0. Turned my share of wrenches in the corps and a big fan of PMCS (preventative maintenance checks and services). That being said i'm in the middle of doing my egr delete and new oil cooler. Everything is going together smooth until my intake manifold. I got it in and started putting my intake bolts in and this is where im confused. I have one bolt left but it seems to short. This truck is 2003 with the intake with the cross member between the rails ( what a pain) anyways im a little embarrassed because that's all I've been doing for the last five years attention to detail. So the sum up is I have one intake bolt left with one hole left but its to short to go into the block. I have my studs with the threads on top in the right places back driver side corner for ficm ground and my two on the passenger side for heat shield and every other bolt is just a intake bolt but long...just left with one short one.... I don't think I dropped or lost one haha and i have my fuel line bracket bolt in and the two 15mm bolts that go in to fan shroud from intake ..s0 who knows... any advice?
fall_n_skies is offline
post #2 of 6 Old 07-19-2013, 05:33 AM
Gus_hauler's Avatar
Do you have the torque sequence diagram for the manifold? If so, double check that and make sure all the bolts are there. My guess is that you have the long bolt that is used to attach the air intake (charge air) on top of the throttle body. Going from memory, but I think it uses three bolts, two short and one longer one. Maybe you put one of the intake bolts in it and have the "Elbow" bolt left.
2004 F-350 Crew Cab LB Dually
"Longhorn Hauler" edition
New Heads!
ARP Studs
Banks Six-Gun with PowerPDA (For gauges only)
EGR Delete from IPR
Rotella ELC
New Turbo from Garrett
Gus_hauler is offline
post #3 of 6 Old 07-19-2013, 06:44 AM Thread Starter
Yea I have it and checked and double checked :/ so im under the impression I lost a bolt. So I just bought one from ford will be here in the morning but im still puzzled because I know I didnt loose it hahs
post #4 of 6 Old 07-19-2013, 06:48 AM
jjvizinat's Avatar
Cant help w the question but good luck. Im still in the corps got another yr an half. Errrr
2006 F-250 King Ranch
Headstuds, OEM gaskets, Updated Oil Cooler, Stand Pipes, Dummy Plugs, STC Fitting (Trucks Unlimited, NC)
35" Toyo Open Country M/T
Coolant Filter with ELC Coolant
Blue Fuel Spring Upgrade
S&B Cold Air Intake
EGR Delete
SCT X4
Nice and clean
jjvizinat is offline
post #5 of 6 Old 07-19-2013, 07:01 AM
Bluedemon6.0's Avatar
Send a message via Skype™ to Bluedemon6.0
I think that is the one that held the oe egr cooler. Maybe you mixed one up? I think that when I did mine that the bolt in the rear of the manifold that held the egr cooler in was discarded. I will take a look at mine this afternoon and see what I have.
-Steven
New!! 2015 Mustang ecoboost!!
Sold!!
formally owned:04 6L PSD CCSB
Studs
Egr delete
S&b intake
New dashboss with fuel pressure and egt
Sct Looney by Vivian and Tonywildman xtreme early lock up now
php 140x
63.5/88mm 06 turbo with a pmax billet WW2
PHP Atlas 80
My baby-
87 jeep wrangler
350 and 700r4 built by mad dawg transmission
Dyno @ 200hp and 400ftlb at 3100 rpm
On 33s
Bluedemon6.0 is offline
post #6 of 6 Old 07-19-2013, 07:16 AM Thread Starter
Gus you were close the one you said on the throttle body was right but it takes 3 shory and one long. The long was the one the one I was trying to use so that means I have to swallow my pride and admit I lost an intake bolt haha
