6.0 no start - Ford Powerstroke Diesel Forum
post #1 of 1 Old 07-17-2013, 03:36 PM Thread Starter
6.0 no start
Ok so here is what i got i bought truck not running installed a set of swamps injectors, did oil change, and fuel filter change. Truck ran great for about a month. then truck started acting up and i was getting a surge on take off and occasionally it would die while driving down the road but would start back up. so since then i have cleaned turbo, pulled injectors back out to check o ring, new hpop. So i was talking to a guy and he said to change crank and cam sensor so for ****s and gigs i went ahead and did it well hasnt ran since. so reinstalled old sensors and nothing. so hooked soulus up to it and im not getting a reading of rpms except a ocassinal 46 to 58 rpm (motor is cranking at normal speed). so ohmed both wires to both sensors both are fine put sensors back in and ohmed the complete circuit and was gettting a variation like i should while cranking. so now im at a loss and need help what do i need to test or do to figure this pos out
04 6 liter swamps 58 v ficm, egr delete, edge attitude, swamps 170 injectors
admorgan is offline
