6.0 EOL Temperature too high? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 07-17-2013, 12:10 PM Thread Starter
Quoted: 4 Post(s)
Hello Forum:
I have a 2006 F-350 Lariat Dually with 50,000 miles on it. This past Spring I changed out the oil cooler, EGR cooler (Installed the Gen 2 cooler) and did some of the recommended updates that Vince at IPR in California told me to do. The oil cooler was a OEM replacement from Ford. 1) Before doing anything I boiled out the coolant system with the acid that Ford sells and then ran another product thru it after the acid bath. I then flushed with distilled water 4 or 5 times (took over a day to do all flushes) I tore motor down and replaced all above parts and replaced everything, no big problems other than a sore back. Replaced coolant with the product from International that sells for about $30.00+ per gallon. It was the type that the forums had recommended to use. Took truck out for a spin and the oil temp and coolant temp was 6 to 8 degrees apart.
I took the truck to Baltimore this past weekend (I live in Ohio) and the coolant temp (198-205) and the oil temp was (248-252) Huge difference while out on the highway. I was not pulling anything, just had the family in the truck. At one time the coolant temp shot up to 235 and the overheat light came on, 30 seconds later the temp dropped as fast as it came up. I pulled into a rest area and checked coolant level, it was fine although I could smell that sweet smell of coolant coming from somewhere.
I drove the truck home with no more issues other than the oil and water temp differences. After getting home I searched for a water leak and found nothing but I can still smell the slight smell of coolant when motor is warmed up. Its not coming from the exhaust so I don't think I have a blown head gasket. MY highway mileage was 18 MPG. I run synthetic "Royal Purple" oil. Any ideas from anyone on what is going on? Is the oil cooler plugged again? I have only driven it maybe 500 miles since the change out of the cooler? Why would the temp spike all of a sudden? I also replaced the thermostat in it and also the pressure cap on the degas bottle. Thank You for your help!
ID:	140338   Click image for larger version
ID:	140346   Click image for larger version
VictorianFarms is offline
post #2 of 15 Old 07-17-2013, 12:15 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Sounds like your sensors might be messing up... Another member is a ford tech that posted the procedure for testing the sensors. I'll post it when I can find it.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 15 Old 07-17-2013, 12:18 PM
Quoted: 8 Post(s)
Here it is... Read post #13
what is considered "high" deltas???
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #4 of 15 Old 07-17-2013, 12:19 PM
Quoted: 8 Post(s)
It's unlikely that your oil cooler is plugged again... But is NOT impossible, other members have had the same problem. This is why I opted for the BPD oil cooler
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #5 of 15 Old 07-17-2013, 02:03 PM
Snake's Avatar
Quoted: 46 Post(s)
OP -- what are you using to monitor temps? And not to cause undue concern, but its very common to blow a head gasket without having coolant coming out of your exhaust. Although not common, there are a number of people who have had a new oil cooler clog or rupture soon after the install.
I hate to suggest it, but it sounds like the new oil cooler clogged, took out the EGR, which then caused your head gaskets to blow.
I also opted for the Bulletproof Diesel oil cooler for the same reasons.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is online now
post #6 of 15 Old 07-17-2013, 02:06 PM
Quoted: 8 Post(s)
This is exactly what happened to me! Good luck
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 15 Old 07-19-2013, 02:41 AM Thread Starter
Quoted: 4 Post(s)
Let me ask you this.... Would the new oil cooler I purchased be undr warranty from Ford? It only has 4 or 5 hundred miles on it. I contacted IPR and he just asked me if I was pulling a trailer and then never responded back. I had purchased everything from him. I do have a SCT tuner on it with custom tunes. I have been running it on "economy" but have bumped it up to "extreme race" and did a few burnouts but that was before I tore it apart and updated. I have been gentle with it since the updates. I might of blown a head gasket a year ago and just dont know it. I went out last night and drove it to the grocery store and could smell coolant in parking lot. Not a strong smell, just that sweet smell coming from somewhere. It might be vapors from the exhaust. ** I should of tore the heads off when I had it tore apart. I was going to do it but didnt have the money at the time to buy the stud kit and it looked like a pain in the butt to do it without the cab off. Everything else I could do with the cab on.. Let me know what you think....... Thanks, David
post #8 of 15 Old 07-19-2013, 06:00 AM
Gus_hauler's Avatar
Do you have dried residue around the coolant cap?
The head gaskets are not hard to do with the cab on. The secret (in my opinion) is to have the AC discharged, and then remove the evap housing. With that gone you've got TONs of room on the passenger side. On the driver's side the only problem is the very back stud/bolt. Buy you can either buy or make an extension that makes it a non-issue.
Here's what I would suggest. Take the truck for a drive for a while. stop, and VERY, VERY, VERY, VERY, VERY, VERY carefully, and SLOWLY unscrew your degas bottle cap. As you unscrew it, does it release a lot of gas and bubble? If so, you've likely got a head problem. And remember, don't assume it is a "blown" head gasket. It could also be you have cracks in the head(s). I had six on one and one on the other.
If there isn't a ton of air rushing out, or bubbling, look around the front of the engine from underneath. See anything wet? I had a lower hose that has rubbed a dimple against the power steering, and developed in pin leak.
2004 F-350 Crew Cab LB Dually
"Longhorn Hauler" edition
New Heads!
ARP Studs
Banks Six-Gun with PowerPDA (For gauges only)
EGR Delete from IPR
Rotella ELC
New Turbo from Garrett
Gus_hauler is offline
post #9 of 15 Old 07-19-2013, 07:17 AM
Snake's Avatar
Quoted: 46 Post(s)
Unfortunately, the oil cooler will not be under warranty either through Ford or IPR unless it's ruptured (telltale is oil in your coolant). The only positive thing I can say is that your programmer didn't contribute to the oil cooler failure. The head gaskets maybe, but definitely not the oil cooler.
Speaking of head gaskets, looking around the degas bottle (coolant reservoir) for signs of a leak, especially around the cap and on the underside of the hood. If you don't find anything there, check the engine valley (the top of the engine where the turbo and oil/fuel filter housings are bolted down).
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is online now
post #10 of 15 Old 07-20-2013, 03:29 AM Thread Starter
Quoted: 4 Post(s)
Should the truck be running at idle while unscrewing the cap?
