Turbo issue when I mat it - Ford Powerstroke Diesel Forum
post #1 of 11 Old 07-17-2013, 07:55 AM Thread Starter
I've notice that when I tromp on the throttle that the turbo will kick in but it's not moving me. I hear what sounds like (hard to easily describe the sound)a hose or pipe disconnected or a hole in something? It's like when you keep your lips together and push air out your mouth lol a fart sound - but not as I've read it being described in the threads I've read...thoughts?
2004 6.0 F250 Crew Cab
ficm rebuilt, atlas 40 tune
egr delete, arp studs, head gasgets
hpop, turbo replaced
oilfieldguypaul is offline
post #2 of 11 Old 07-17-2013, 08:36 AM
Maybe an intercooler boot leaking?
Moto2four is offline
post #3 of 11 Old 07-17-2013, 09:56 AM Thread Starter
I'll check into that, thanks - once the temps here get below the surface of the sun, wow..
post #4 of 11 Old 07-17-2013, 01:38 PM
Another easy thing to check is up-pipe leaks, there will be soot all around the area if they are leaking.
post #5 of 11 Old 07-17-2013, 01:40 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I just found a leak on the EGR valve were it seals to the intake so dont forget to check that.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #6 of 11 Old 07-17-2013, 02:41 PM Thread Starter
Thanks for the replies guys, I think I'll actually venture out of the a/c to check it out now.
post #7 of 11 Old 07-17-2013, 03:30 PM Thread Starter
[IMG][/IMG]
post #8 of 11 Old 07-17-2013, 03:32 PM Thread Starter
OKAY I finally figured out how to post a pic! So...the one turbo pipe (expert here eh/) has oil sweating on it apparently...also, I was supposed to have the EGR Delete done with the head gasket job...um how will I notice if it's been done?
post #9 of 11 Old 07-17-2013, 03:33 PM Thread Starter
I didn't notice any holes/unconnected parts...
post #10 of 11 Old 07-19-2013, 09:04 AM
2004 f250 rpms go to 3000 and no power new turbo and egr dalete need help thanks in advance i am new to this
Danny123 is offline
