6.0 starting issues after lpop and hpop - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-16-2013, 09:17 AM Thread Starter
ok I am new with the powerstrokes, not mine working on work trucks. I can work on them,and not the first hpop ive changed, just don't know what everything is. first truck was diagnosed with bad lpop and hpop. they wanted a butt load of money to change them so I did it. lpop new from dealer, hpop remaned off of ebay. changed ipr with the hpop. got all back together and cranked for 10mins and fired up. it would studder a lil bit but after test drive, drove until operating temp, shut it down and now it wont start. it has oil in the filter housing, looked like it had some air bubble in it when first cranked, but then filled up quickly. shoved very lil either down its throat after glowpugs cycled and it wanted to fire but didn't. im at a standstill on this thing. and help is very much appreciated. or even give me a direction to go. thank you for your time.
matzkepj is offline
post #2 of 7 Old 07-16-2013, 09:19 AM Thread Starter
sorry for not saying what im dealing with. its an 07, 6.0 f250
matzkepj is offline
post #3 of 7 Old 07-16-2013, 04:08 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
Need to know your ICP and IPR numbers. There are a number of other parameters, but since you worked on the oil systems, lets start there.
Please tell me you didn't crank it for 10 minutes? It should have fired to life after 2 or 3 20-30 second cranks.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 7 Old 07-22-2013, 06:31 AM Thread Starter
nope didn't crank straight for 10 mins. but I did pull it back apart to see if I pinched o ring on the hpop. didn't. pulled dummy plugs and standpipes and replaced them, as they were bad. put all back together and still no fire now. I don't have the equipment to really test anything due to me not going to buy it for a work truck and bossman to cheap to buy it. so I go off of what I can. I have oil in the filter housing and oil gauge jumps up on dash when cranking. changed fuel filters and rigged up a guage to test pressure and I got 45 when keof. I tested ficm and I have 48 vlts when keof and no drop when cranking. if I cant figure it out I just tell him to take it to the dealer. not my money.
matzkepj is offline
post #5 of 7 Old 07-22-2013, 03:47 PM
without codes or live data it is almost impossible to trouble shoot a 6.0 very well
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #6 of 7 Old 07-22-2013, 08:04 PM
Quoted: 47 Post(s)
A M12x1.5 to air fitting is pretty inexpensive. You can pressure test the HPO system and rig up a simple wiring plug to close the IPR as needed. Go to this thread for some advice.
Am I testting ICP the right way?
Frank
Working for Toys
post #7 of 7 Old 07-23-2013, 12:10 PM Thread Starter
I was just in process of rigging something up to test the system. I pressured up to 100psi and sure enough gotta pull it all off again. heard a lil hiss on the back of the engine. I will let yall know what I find. thank you for your help.
matzkepj is offline
