04 6.0 leaking - Ford Powerstroke Diesel Forum
post #1 of 3 Old 07-16-2013, 05:56 AM Thread Starter
007.3Powerstroke's Avatar
04 6.0 leaking
well i walked outside of work yesterday and i had a pool of something leaking under the drivers side of my truck. it only does it after is has sat for a long time im talking 4+ hours. so last night i checked coolant it was a little low. so i topped it off. didnt drive it at all last night. it sat for over 12 hours, had a bucket under it to catch whatever was leaking. and it didnt leak so i couldnt see what it was. truck does have an EGR delete. Im lost on what it could be. i didnt see any thing after i drove it home last night so i cant really see where its leaking from. I kinda lost here. so anything would help. Thank you
2004 6.0 Lifted 8 in 37x14.5x20 inch tires
mods so far:
SCT W/ Tunes
4 in from the turbo back.
Glow shift gauges EGT Boost and Trans temp
HID Headlights
HID Foglights
EGR Delete
03 Turbo
Studs and Gaskets
Coolant Filter Kit
007.3Powerstroke is offline
post #2 of 3 Old 07-16-2013, 06:16 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
So when you look up at the engine from below, what do you see? Coolant will cling to the engine and you can see the drips ready to come off. Usually any coolant leaks will show drips hanging on the starter or other protrusions on either side. You may even see it in the valley if you look for it, especially if you use Red ELC, even if there are no drips on the ground. Since you said driver's side, the degas and hoses below come to mind, as well as the main hose to the thermostat (frequent drip location) or even the power-steering system.
You need to catch some evidence!
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #3 of 3 Old 07-16-2013, 06:36 AM Thread Starter
Well that's the problem ive looked and dont really see anything after it is parked. i tried to catch whatever was leaking last night in a bucket. but it didnt leak. im sure it will leak today while im at work. ill look at the cool system tonight after it cools down and i can get my hands on it.
mods so far:
SCT W/ Tunes
HID Headlights
HID Foglights
EGR Delete
03 Turbo
Studs and Gaskets
Coolant Filter Kit
