heads cracked ? whats the chance? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-15-2013, 02:42 PM Thread Starter
8 LUG THUG's Avatar
04 f350 puking out the degas bottle when i tramp on it (SCT live wire ts w/ MPT custom tune called bazooka) up to 35 psi boost
i filled up the degas bottle to the top and started the truck, yup bubbles coming to the top every 5 seconds, i was told the HG is blown
my question is.... i had ARP head studs done at 90 k truck now has 160 k
what are the chances that the head or heads are cracked? i cant see the hg being the only thing wrong considering i have head studs
my second question is.. could i get air in my coolant from a leaky injector cup and how common is that?, i was WELL over the limit on my last oil change and could smell diesel in the oil when i changed it, i had a "sticky" injector or something till i added REV-X truck runs fine now,
B L A C K T H U N D E R - 2004 f350 Lariat - Amsoil, SCT livewire ts , ARP head studs, banks intake, egr delete, ccv relo., Racor fuel filter, banjo bolts, 5'' str8pipe,10'' lift on 37'' toyo opens... BEWARE of Dozers diesel! do research before you order anything!
8 LUG THUG is offline
post #2 of 5 Old 07-15-2013, 08:05 PM
Gus_hauler's Avatar
Do you remember what gaskets you used? I have heard that some of the aftermarket gaskets have been found to fail even with the ARP studs.
2004 F-350 Crew Cab LB Dually
"Longhorn Hauler" edition
New Heads!
ARP Studs
Banks Six-Gun with PowerPDA (For gauges only)
EGR Delete from IPR
Rotella ELC
New Turbo from Garrett
Gus_hauler is offline
post #3 of 5 Old 07-17-2013, 12:35 PM Thread Starter
8 LUG THUG's Avatar
it was done at the ford dealer under war. at 90k, i just ran in with a box of head studs. so im guessing an oem hg
post #4 of 5 Old 07-17-2013, 01:42 PM
gotta_gofast's Avatar
Quoted: 61 Post(s)
I'm going through a similar situation. Ford dealer did HGs at 50K with ARPs and now at 100K I am pulling the motor myself to do things right. With no record of cylinder head machine work on my OASIS report, I can only assume the dealer slapped new gaskets and studs on without cleaning/truing the heads and deck. I won't know "for sure" until this weekend when I disassemble the motor.
FYI. the heads are known to micro-fracture around the valve seat. I've budgeted for the machine shop to cut out the integrated valve seats and press in steel valve seats (plus a 3 angle valve job and new guides, ect...). However, it is rare that these cracks will be deep enough to reach the cooling passages.
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #5 of 5 Old 07-17-2013, 01:53 PM
Snake's Avatar
Quoted: 46 Post(s)
Head gaskets can still fail with OEM head gaskets and studs. Even if the install was done correctly and there were no issues with the heads at the time. I don't know how you drive your truck or what tune you're running, but 70k miles have passed. It's very possible that your head gaskets are blown again. It's happened to me. Twice.
Based on your symptoms, it sounds like they are. A good indicator of a cracked head is fuel in your coolant. However, it's possible to have cracks in your heads without having fuel in your coolant, but not with the symptoms you're describing.
Truckless
Bulletproof Diesel
KC Turbos
1-A Auto Parts
Snake is offline
