Oil but no presure - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-14-2013, 10:03 PM Thread Starter
Oil but no presure
Here is the story on this truck, it was driven with a blown head gasket until it became a no start. Replaced gaskets, ARP studs, new oil cooler and EGR delete. drained 6.5 gallons from the crank case. Contents of the cooling system. The truck was still a no start. I had no HPO. I did find a bad HPOP and replaced it. No Start. Started to dig deeper and I have found that I am getting oil filling the filter housing but I have no oil pressure on the low side. No oil is getting to the pressure sensor. I am getting a light flow of oil from the turbo supply line but has little to no pressure. Any suggestions would be very welcome at this point.
Myers407 is offline
post #2 of 2 Old 07-14-2013, 10:37 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Sounds like a Low pressure oil pump failure to me…
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
