Component missing - Help - Ford Powerstroke Diesel Forum
post #1 of 9 Old 07-14-2013, 06:44 AM Thread Starter
I recently bought a 2006 F250 6.0 SD. On the passenger side of the engine compartment i have a missing component that I need help figuring out what was there. Here are pictures of the connections:
ID:	138801   Click image for larger version
Tom's 2006 6.0 is offline
post #2 of 9 Old 07-14-2013, 06:47 AM
STANGMAN893's Avatar
Looks like the vacuum solenoid. Sits next to the vacuum pump. or the vacuum pump. Been a while since I replaced mine.
STANGMAN893 is offline
post #3 of 9 Old 07-14-2013, 06:48 AM
Think I see the pump under your hand.
post #4 of 9 Old 07-14-2013, 07:01 AM Thread Starter
No the vacuum line does T off and connect prior to the missing component to that. Here is another pic of where it is supposed to be bolted to the side. It takes two bolts:
post #5 of 9 Old 07-14-2013, 07:13 AM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
Hope this helps. Here are some pics of the wires and solenoid on my 04.
*Edit* stangman is correct, you are missing your solenoid.
ID:	138825   Click image for larger version
Name:	electrical con.2.jpg
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #6 of 9 Old 07-14-2013, 07:17 AM Thread Starter
Well that would be the missing component... Now what is it? What does it do? The previous owner had to have taken it off for some reason.
Thanks so much for the help so far guys...
post #7 of 9 Old 07-14-2013, 07:23 AM Thread Starter
Sorry just saw that you are saying it is my vacuum solenoid. Why would someone remove that?
post #8 of 9 Old 07-14-2013, 07:32 AM
When mine stopped working and I lost the 4x4 in the middle of a blizzard and locked my hubs manually.Could have been removed cause it didn't work to match it up and never got a new one cause it wasn't a major issue.
post #9 of 9 Old 07-14-2013, 07:39 AM Thread Starter
That makes sense.
OK so just get out and lock them manually and all is good.
Thanks again everyone for your help...
