EGR cooler - Ford Powerstroke Diesel Forum
post #1 of 10 Old 07-13-2013, 03:43 PM Thread Starter
EGR cooler
Have everything disconnected egr cooler moves around haven't hose yet.
Have bolts out that hold cooler in place, but cooler won't drop so I can pull it out. Any trick? Tried taping it with a hammer, lightly won't drop.
letitsno is offline
post #2 of 10 Old 07-13-2013, 03:59 PM
hdodt's Avatar
It fits into the intake manifold where the two bolts on the front are. Get a pry bar in there and pry it out.
2006 F350 Lariat
EL CAT1 coolant and coolant filter.
95k miles. Oil cooler changed at 93k.
Oversized turbo oil drain tube.
hdodt is offline
post #3 of 10 Old 07-13-2013, 04:15 PM Thread Starter
Figure it's the o-rings holding it in.
letitsno is offline
post #4 of 10 Old 07-13-2013, 04:17 PM
hdodt's Avatar
Yeah. It's tight in there but it should drop out.
2006 F350 Lariat
hdodt is offline
post #5 of 10 Old 07-13-2013, 04:21 PM Thread Starter
Oh forgot to say it a 2005 E450 box truck. Harder to get a pry bar in their.
letitsno is offline
post #6 of 10 Old 07-13-2013, 04:23 PM
hdodt's Avatar
Ahhh... well good luck.... you could just pull the manifold off.... that in its self is a pain, but at least then you could clean that out.
2006 F350 Lariat
hdodt is offline
post #7 of 10 Old 07-13-2013, 04:39 PM Thread Starter
Hopping to not have to too do that, have to get a different crow bar.
Good thing I have a lot of patience, going to try cutting the old hose.
Later
letitsno is offline
post #8 of 10 Old 07-23-2013, 04:13 PM Thread Starter
Ok still can't get it out, so I called custom-diesel.
6.0L engines in van's have intakes closer to engine block.
So gonna pull intake, wish I would have known, probably in instructions, lost them. Guess I can't pry engine out from under intake.
Had I known I would have pulled intake right away.
letitsno is offline
post #9 of 10 Old 07-25-2013, 12:01 PM
Quoted: 5 Post(s)
I don't think there's room to get the EGR cooler down out of the intake without raising the intake some. There's a bunch of threads about people installing EGR delete kits and I've looked at a few, that's where I think I remember seeing that. I took my intake out and had a hard time getting it out until I had the EGR cooler mounts all unbolted, the o-rings are pretty stiff in the intake.
Idahoser is offline
post #10 of 10 Old 07-25-2013, 02:45 PM Thread Starter
Intakes on vans are 4 mm thinner/lower enough to the block that cooler won't drop out.
Why you would make a different part for vans, 4mm why bother.
Any way intake is out being boiled out, last one they did he said it took 2 days to get it clean. Did find another oil leak at injector wiring through head. More parts & have to remove valve cover. Connection was all covered with oil, laptop showed an issue with #5
injector. It ran fine no misses, oil probably screwing up the signal. Found some more chaffing on wiring harness and a lot of rewrapped wires, hope they fixed them right.
So far what I hate is the oily tape mess. Patience, you need lots of patience. Now to order some more parts, pull & clean turbo & clean valley.
letitsno is offline
