rough running 6.0 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-13-2013, 03:20 PM Thread Starter
rough running 6.0
ive been reading lots of post and talking to people trying to figure out what exactly is going on with my truck and I think I have finaly figured it out but I just wanted to ask on here before i start throwing parts at it
ok truck is 2005 6.0 6 speed only thing that has been done to it is staight pipe and Edge cs. It does also have 2 pyros 1 boost 1 trans temp on the pillar.
Now for the problem ill start the truck of a morning and it will just slightly have a miss/sputter at an idle. normally i will let it warm up but if i start driving it before the oil and coolant gets up to 150* it will spit and sputter horribly, bad anough i cant go over 50mph. Once it over 150* though it runs nice and smooth with full power like nothings wrong, but if i come back to idle even when its warmed up it will still have a slight miss or sputter.
I unhooked my egr valve with the truck off to close it and rule that out.
I unhooked my icp sensor to see if that stopped it and that made no differance.
I have dumped fuel treatment in the last 2 tanks and it seems to work at first but then the issue comes right back
no codes have been coming up but yesterday i checked it and i had a P0269 cylinder3 Contribution/balance. i erased it and it hasnt came back yet
So i am assuming cylinder #3 injector is bad. Am i correct in this assumption or could it be something else. also if it is bad am i better off to replace all 8 instead of just 1 ?
sorry for the long post i just like to be thourough. thanks
benp is offline
post #2 of 7 Old 07-13-2013, 05:03 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 236 Post(s)
Sounds like stiction, or a bad FICM. Have you checked FICM voltages with your EDGE CS while its doing this? Also check your batteries health and the health of your alternator. Easiest thing to try for a stiction issue would be a Rev Ex treatment and switch to a full synthetic motor oil. To go deeper, and for the cost of injector seals,you can pull your injectors, and hand polish your spool valves. Most expensive option... replace all injectors.
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW See my visitor messages for my mods
Edge Insight & SCT X4 FOR SALE
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #3 of 7 Old 07-13-2013, 05:20 PM
twoicebergs's Avatar
Quoted: 43 Post(s)
Usually one injector wouldn't create what you are seeing, unless you are very sensitive to the miss, but 2 or more would. It might just be that finally the miss was large enough to set the code. Checking all the diagnostic parameters would be a good idea rather than jumping on the injector(s), even though it is more than likely a spool stiction or nozzle issue, being that it completely disappears at normal operating temperature. Who knows, maybe you have some water in your fuel and once the tank gets stirred it is OK.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #4 of 7 Old 07-13-2013, 05:23 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
agreed, what he said.
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
post #5 of 7 Old 07-13-2013, 09:45 PM Thread Starter
The ficm isnt very old, I bought the truck a couple months ago so all I know is it doesnt look to old. But the volts are usually 48 or 48.5 ocasionally they will hit 47.5 but never lower.
I have been having issues with my interior lights and load light staying on but hadnt thought nothing about it since truck still started fine. I just checked it and its at 11.7. I know thats low but it that my problem?
What r the benifits of full synthetic? I use Rotella 15-40
And what is stiction issues
benp is offline
post #6 of 7 Old 07-13-2013, 11:14 PM
Quoted: 236 Post(s)
You cant go on looks alone, with a FICM, especailly if its running a "FICM Killer" strategy. Monitoring its logic power and output are a must. You never want to see output below 45v. That is a good way to ruin injectors.
11.7V on a fully charged battery is not a good sign. It is said that the number you should see on a battery after it sits over night should be about 12.9V. But that in itself is not a good indicator of battery health. Individually load testing them is the best way.
Then there is the alternator. The OEM alternator is very undersized. I recently upgraded to a DC Power Engineering 185 amp alternator, and let me tell you, its a whole different truck.
Switching to a full synthetic is beneficial for several reasons. Its lighter weight and easier to move when the engine is cold. It has better lubricity. It is not going to create the varnish on engine parts with tight tolerances, namely, the spool valves of the injectors.
Stiction, is the build up of varnish on the spool valve of the injector and basically slows down the reaction time of the injector, which creates wrong injection timing and poor performance, especially when cold. You should hear the injectors buzz for a few seconds during the glow plug cycle, before you start the truck. This is inductive heating, trying to fend off cold stiction.
If you want more elaborate explanations, you can either google it, or just search here on the org about it. Twoicebergs has some great, very informative and educational links in his sig you should check out about stiction, curing it, and how the injector works.
post #7 of 7 Old 07-21-2013, 11:27 PM Thread Starter
Probably should of replied much sooner but I had been waiting for my rev ex to show up
I drove to the shop to get it poored in both bottles and drove 15 miles to work. I really didnt pay much attention to how it ran on the mad dash to work but after I got off work I started it to let it warm up like normal and it ran smoother than it ever had. All my problems disappeared. Even when I would try to get on it while it was cold. And no symptoms have even began to come back.
So any one wondering about rev ex yes it does work
And thanks everyone for the help
benp is offline
