Excursion low batteries?? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 07-08-2013, 09:00 PM Thread Starter
jbenoit28's Avatar
Quoted: 3 Post(s)
Our truck just recently began not starting on try. We try immediately again and it starts. This has only happened 3X so far. I search the forum and found several things to check. I have a FICM from swamps, the oil cooler was replaced and several of the updates done while my mechanic was in the engine that deep. I have the Edge CTS and this is what I found:
FICM was 48.5v-49.0v off, just started or running.
ICP was in the 500's right after starting, and in the 900-1000 range while driving around town.
Voltage was 11.9v while off, dropped as low as 8v while cranking, it goes back to 11.9v to 12.2v while running.
The batteries are a little over 2 years old. I'm in Florida and it's summer, there is nothing cold going on around here but my AC. I'm running Interstate Mega Tron Plus MTP-85's. 850cca and 1000.
I read about the 7 pin bargman trailer plug can have a bad ground and drain the batteries. That seemed similar to my issue as the longer the truck seems to sit the slower it cranks.
I unplugged the trailer harness at the back of the truck and then checked the battery using the CTS. It was still low, dropped to 8.5v while starting, but after driving it around for awhile, it climbed up to about 13.3v and when I came to a stop it would stay around 13v. I used a multimeter on the batteries and each had about 12.5v I started the truck again, waited a bit, then checked them and each had 13.4v
So my question is Am I on the right track? It looks like I had a short in the trailer harness, so I should replace it. I'm hoping that I didn't hurt anything by running with the low voltage as I'm not sure how long this was going on before the truck began the no start condition. Should I charge the batteries or let the alternator deal with it?
Sorry for the novel, just trying to give the info that I know currently. Any help or advice would be appreciated. Thank you,
Joe
jbenoit28 is offline
post #2 of 16 Old 07-08-2013, 09:09 PM
Like a boss!
Laferty's Avatar
I would get the batteries tested for state of health. If is a common misconception that if they have 12+ volts then they are good. It is possible to have the 12 volts but only have 100 cranking amps. Getting them tested will tell you the cranking amps of the battery, not just the voltage. If they test fine then awesome. I've read good things about the Megatrons. After that I would get the alternator tested. As for testing the trailer plug, google how to do continuity checks with your meter.
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #3 of 16 Old 07-08-2013, 10:42 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 445 Post(s)
Garage
You most likely have a battery issue going on. Like stated above 12.6 volts means nothing when cranking voltage is 8 volts, which by the way is not enough for the ficm to stay on to get it started.
If you have a battery drain you need to track it down. 10.6 volts is really as low as you want to see while it's cranking. Anything less is not a good thing. Try charging batteries up overnight and see how it does for you, if it still drops down low while cranking then you do have battery issues. Unless you have bad grounds or starter issues.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is online now
post #4 of 16 Old 07-09-2013, 06:17 PM Thread Starter
jbenoit28's Avatar
Quoted: 3 Post(s)
I put the charger on it this morning (passenger side only) and let it run all day. I got home and disconnected it all. Still had 12.6v on both batteries. Started it and it still shows 11.9v on my CTS gauge and drops to 8.5v while cranking. It fires right up though and seems to run just fine. I did notice that the ICP was at 800 right after it fired up today.
I will take the truck to the local Advanced Auto and have the batteries and Alt tested. What is the deal for doing that with dual batteries? Pull the positive off one of the batteries while testing them?
Thanks,
Joe
post #5 of 16 Old 07-09-2013, 10:02 PM
Like a boss!
Laferty's Avatar
Thanks,
Joe
I would completely unhook them while having them tested. Then there is no possibility for a faulty result. I haven't paid attention to my numbers while starting the truck. Maybe I should begin to.
2006 CCLB
Laferty is offline
post #6 of 16 Old 07-09-2013, 11:36 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Each battery must be tested individually… Les Schwab tested my batteries three times telling they were great just to find out they were testing both at the same time and when I took it to a shop they recommended, they failed with flying colors…lol save the time and just take the batteries out of the truck so you know it's done one at a time. IMO it's your batteries…. Good luck
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #7 of 16 Old 07-10-2013, 07:47 AM Thread Starter
jbenoit28's Avatar
Quoted: 3 Post(s)
I went to Interstate battery where I got the batteries and they tested them. Passenger side was barely 6v under load. Other one was fine. They replaced the bad one under what was left of my prorated warranty. I know I should do both, but can't afford it right now. I think I had a short in that trailer harness causing all of this. I will have to look into it and figure it out.
Now when I start the truck, volts drop to 10.8v, then go up to 13.1 to 13.5v when I'm driving. I've never seen 14v on my cts gauge.
Thanks for all of the help on this.
Joe
2005 Ford Excursion Diesel 4X4 with Roadmaster Active Suspension, F350 1 3/16" rear sway bar, Bilstein shocks & steering damper. Sinister Coolant Filter, ELC coolant, bulletproof EGR Cooler, all usual 6.0L updates short of head studs and gasket. CTS Gauges. Stock Tune.
post #8 of 16 Old 07-10-2013, 08:51 AM
Quoted: 8 Post(s)
Nice, glad to see ya got it fixed!
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #9 of 16 Old 07-10-2013, 06:00 PM Thread Starter
jbenoit28's Avatar
Quoted: 3 Post(s)
I read in other threads that purple are seeing 14v while driving. Is that normal with a stock alternator? I'm only in the low 13's no matter what I do. Should I have the alternator tested as well?
Joe
post #10 of 16 Old 07-10-2013, 08:49 PM
Like a boss!
Laferty's Avatar
Mine stays above 13.6 and 80% of the time above 13.8. I have the dual alternator system. If your voltage is dropping like that then I would say it has to be an alternator. Do you have your high idle mod done? If so then does it drop or fluctuate the same on high idle?
2006 CCLB
Laferty is offline
