oil pressure light comes on while driving and truck loses power - Ford Powerstroke Diesel Forum
post #1 of 4 Old 07-08-2013, 03:44 PM Thread Starter
Question oil pressure light comes on while driving and truck loses power
like the title says truck loses oil pressure at the gauge the light comes on but truck keeps running and will come back to life after about a mile or so. the truck is one of my wifes co-workers and the dealer quoted him 4,000.00 to fix it. I figured I could scrounge a little extra cash by fixing it but im not sure of this problem. he wants an egr delete done which I have done before but this one is new to me. could it be a oil drain back problem?
chadc2008 is offline
post #2 of 4 Old 07-09-2013, 04:56 AM
dxusmc's Avatar
most likely oil drain back problem causing the gauge to go out, but the lack of power is probably from the high pressure oil system. What year is the truck? If its 03-04 might've lost the pressed bearing in the high pressure oil pump itself. When this happened to me, I had these exact symptoms.
If it were just the gauge without lack of power, I'd say replace the pressure sensor, they're known to go out. Truck wouldn't run without low side oil pressure, but to be sure you have it, take out your oil filter and stick an extension or screwdriver down to the plunger. Have someone crank it over, if the bowl fills up with oil, then your low pressure gears are working. That would at least point you in the direction of the high system again. Best way to find the leak is with an air test through the ICP port and command the IPR closed. If this truck is 05+ then I'm really not sure. Don't know if the STC fitting would kill the pressure on the dash. I only know what I've already been through on mine.
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #3 of 4 Old 07-09-2013, 06:15 AM Thread Starter
It is an 05 but the more I read last night it sounds like stc fitting may be the culprit if it is broken enough it could cause lpop pressure to go low but I don't really wanna tear into this thing and replace a bunch of parts if there is more wrong my tools are somewhat limited as far as diagnostic stuff but I'm just trying to help the guy and he does want the Egr delete done so I figured I would do the oil cooler and stc fitting hopefully it hasnt ruined the hpop yet. He hasn't driven it in 4 months.
post #4 of 4 Old 07-09-2013, 07:12 AM
dxusmc's Avatar
I doubt the hpop is bad..simply because it still runs. If that thing was blown, your injectors would starve and you'd be calling a tow truck. The hpop will be really easy to get to since you're doing an EGR delete. If you're actually replacing the cooler that is with something else..or even capping it off. 8mm bolts on the hpop cover, pry it off..there you have it. If the STC hasn't been upgraded, then it wouldn't be a waste of parts regardless. It will be a good investment and I'd be willing to bet when you pull it out, that its broken.
Marines 2004-2009
Army 2009-2013
dxusmc is offline
