Hole in oil filter cap. - Ford Powerstroke Diesel Forum
post #1 of 5 Old 07-08-2013, 01:07 PM Thread Starter
biged681985's Avatar
I bought a 6.0 powerstroke cheap. The guy I got it from said it blew a hole in the oil filter cap. he started tearing into the truck. tore the intake, turbo and oil cooler out of it. said it was running fine when it blew a hole in the cap. ford dealer told him it was the motor. im guessing the dealer thought the same thing I did at first is it was the oil fill cap, but it is the filter cap that is bad.
from some reading I have done, I have not seen anything on this besides it just being a bad oil filter cap. and one heard anything like this? or have had this problem?
biged681985 is offline
post #2 of 5 Old 07-09-2013, 02:30 AM
With a hole in the cap you will eventually pump all of the oil out of the engine. Without oil to lubricate and carry off heat generated by internal moveing engine parts those parts quit moveing, resulting in massive internal damage and a dead engine.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
post #3 of 5 Old 07-09-2013, 03:25 AM
Unapologetically American
2006PSDSD's Avatar
Quoted: 30 Post(s)
Feedback Score: 4 reviews
Sounds like there's a ton of pressure where it's not suppose to be . Put a new cap on and see what happens. Or start the truck and see how much pressure is there
2006 F350 SOLD
* KMC XD Monsters wrapped in Hankook ATM's
* 08 style mirrors
* 4" TB exhaust
* SCT X2 with Gearhead, PHP and ID tunes
* Edge Insight CTS
* Blue FPR spring
* 6.4 Banjos
* Dfuser coolant filter
* Stage1 MTW turbo
New truck has a Cummins and a handshaker
2006PSDSD is offline
post #4 of 5 Old 07-09-2013, 06:13 AM
twoicebergs's Avatar
Quoted: 47 Post(s)
If the cap was cracked it is entirely possible to blow the top or piece out of the filter housing and nothing else to be broken. You got it for a good price, replace the cap and put a monitor on the vehicle and see how it behaves.
The HPO not running the injectors would have helped prevent damage to the engine internals, but doesn't rule out internal damage.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #5 of 5 Old 07-11-2013, 05:48 AM Thread Starter
thanks for the info. I'm hoping I can just put a cap in it and it be fine.
if it does end up needing a motor it will be getting a 12v with a built 47re. that's the main reason I bought the truck thinking it had a bad motor. but if I can fix it with just a oil filter cap, then ill try selling it.
