04 f350 6.0 won't start unless spry help - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-08-2013, 10:27 AM Thread Starter
Cant get my truck to start now if I spry starting fluid I can get it too run but only in high rpm if I let it drop to 1200 it shut off n won't start unless I spry again any ideas thanks. ..
Manny's powerstroke is offline
post #2 of 7 Old 07-08-2013, 10:49 AM
Quoted: 888 Post(s)
Feedback Score: 3 reviews
DONT EVER DO THAT AGAIN. Powerstrokes hate starting fluid. You can and will blow it up.
Obviously you have a fuel issue, either your fuel pump or FICM isn't working properly. Hopefully someone with more experience with the 6.0's will chime in to help you. That's where I would start though.
Utilize the search in the 6.0 forum.
Corey@CNCFAB is offline
post #3 of 7 Old 07-08-2013, 10:56 AM
kendallcschm's Avatar
Send a message via Skype™ to kendallcschm
do you have a monitor we can look at? whats the truck sound like when its cranking over.. and whats your FICM voltage.. to me it most definitely sounds like an FICM issue to me.. does it start to chug and then shut off at lower RPMs
2007 Ford F250 Lariat 6.0 Powerstroke
mods:
Banks Ram air
Sinister Coolant Filter
Swamps 48V FICM with PHP Atlas 40
B&W turnover ball hitch
EGR Delete
Diesel Site Intercooler Boots
SCT livewire TS 5015 w/IDP custom tunes
Agressive street, Tow W/jake brake, Economy
Other rides:
2010 Ford Explorer 4.6 24V V8
1999 Ford Mustang Cobra 4.6 32V V8
Mods:
JLT True CAI
Smoked Heads/tails
kendallcschm is offline
post #4 of 7 Old 09-03-2013, 09:24 PM Thread Starter
Friends of my put his scanner n couldn't get a reading on the ipr valve can that stop my truck from starting? Any help thanks
post #5 of 7 Old 09-04-2013, 01:33 AM
JustinOOO9's Avatar
Quoted: 574 Post(s)
Garage
what this guys videos on diagnosing different types of no start situations for our 6.0's hes really good and has simple ways for checking.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s, JW Vbody.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is online now
post #6 of 7 Old 09-04-2013, 07:18 AM Thread Starter
I will take a look at it thanks
post #7 of 7 Old 09-05-2013, 05:32 PM
bondsman's Avatar
I just fixed an 05 that would not idle. I could press the pedal and it would run, as soon as I let off it would not idle and die. Auto enginuity would keep it running at 1000rpm, but any less it would die like you turned the key off. Checked everything I could think of. Ohmed out the cam sensor and it was good. Called a friend and he said that he ran across a similar situation and it ended up being the cam sensor that was weak. So I changed mine and it works like a champ now. Idles great. It is supposed to be between 800-1000 ohms. Mine was 876ohms and still bad.
05 F250 4x4 CC, 9.5" Rize/Icon, 38" Toyos, 20x12 Pacers, 5" MBRP, AFE stage 2, Cass 190s, Powermax, ELC w/filter, RCD EGR delete
04 Excursion 4x4, vacation bus
Project 1979 F250 6.0 powered in progress
bondsman is offline
