Coolant low after long trips and a P0284 - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-07-2013, 05:58 PM Thread Starter
I just hauled two 30ft combine headers hooked to each other with my 04 6.0 and when I got to our destination it was loping pretty good (P0284) and noticed it was half a gallon low on coolant(temps were about 230f). When I started it up the next day I filled coolant back up and there was no lope anymore until I started driving and stopped and shut it off and it started loping again. When I pulled these trailers it was 101 out with a 30mph crosswind and going up at steep grade for about 300 miles. by boost pressure stayed above 20psi for most of the journey and I only have a Egr delete and straight pipe. Im nervous guys please help its my only mode of transportation.
vinniehobart is offline
post #2 of 7 Old 07-07-2013, 06:04 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Did you see any signs of puking? Are you filling to the new full mark?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 7 Old 07-07-2013, 06:31 PM Thread Starter
Yes it had some puking..I put about 48oz to get it back up to the proper line. I drove it 400 miles today to get back home and coolant was at the same line. the coolant temp and oil temp are still good only 2 degree difference and still averaged 17.5mpg
post #4 of 7 Old 07-07-2013, 06:44 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Are you still running the original degass bottle cap?
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 7 Old 07-07-2013, 06:48 PM Thread Starter
everything is original
post #6 of 7 Old 07-07-2013, 07:00 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Do a quick search. Just put in that p0284 and their is a lot of info. ( Id tell ya for sure what the code means if I knew for sure myself...)
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 7 Old 07-07-2013, 07:02 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
As far as the cap they are known to fail with time. Fluid under pressure boils at a higher temp. so if your cap is not holding its 16-17 psi your truck could basically boil over and puke. Plus its a cheap hopeful fix.
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
