Broken piston? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 07-04-2013, 09:35 PM Thread Starter
Broken piston?
I was recently running down the interstate on Vivians tow tune, when I exited I noticed a shudder when the converter was locked at 50mph. I also discovered a very rough idle. I scanned the code. p0272. I assumed #4 injector, I swapped it out with no change, same code too.
So here are my symptoms in a nutshell
1. p0272
2. rough idle
3. when cranking it hits 7 times, then on the 8th it skips, as if one cylinder has no compression.
4. smoke comes out the oil fill cap and dipstick.
5. stinky whiteish gray smoke at idle.
By the way I am getting smoke in the crankcase and the way it cranks over I am thinking a cracked piston. Any ideas?
03 F250 CC/SB 4x4
225k Miles
Dual Exhaust
All Else Stock
renegadedooer is offline
post #2 of 2 Old 07-06-2013, 11:18 AM
Manual compression test of suspected cylinder needed to confirm your suspicions.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
