White Smoke - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-04-2013, 08:40 PM Thread Starter
ZCMiller's Avatar
White Smoke
My 2007 with 155,000 miles has been blowing white or white-ish blue smoke when cold. By cold I mean when first started and not up to operating temperature. It has studs, egr delete, blue spring, gasket, and SCT tuner. I change filters religiously and lose no oil or coolant. A local mechanic had me attempt to check the valve in the oil filter housing and I am confident that it is functioning properly. He then mentioned glow plugs. The smoke persists anytime the truck is started until the oil temp is up to about 170. The Livewire TS is not reading any injector codes or any codes at all for that matter. I've been researching turbo seals but what I've read seems to be at take off not at start up until warm. I am just wanting the smoke to stop, the truck runs like a champ but its embarrassing and I am tired of being asked why my truck smokes so bad. Wondering if anyone had any clue what the issue is. Thanks
'96 F-250XLT 4x4 Regular Cab
ZCMiller is offline
post #2 of 7 Old 07-06-2013, 12:52 PM
gavol64's Avatar
white smoke at start
I HAVE THE SAME PROBLEM! IT IS DRIVING ME CRAZY AND I CANT FIGURE OUT WHAT IT IS! CAN SOMEONE HELP US?
2003 F250 superduty Crew Cab 4x4 - 4" Rancho lift, Rancho 9 way adjustable shocks, CAT Delete, Royal Purple Synthetic Oil, Royal Purple Transmission and Differintial Fluid, Hypertech Transmission Pan and Differintial Cover, Edge CS Guages, EGT Probe, Dick Cepek 315x75x16, EGR Delete, Roll n Lock Bed Cover, MBRP 4" Turbo Back Exaust, Rev-X, 2005 Grill, Line X Bedliner.
gavol64 is offline
post #3 of 7 Old 07-10-2013, 12:05 PM Thread Starter
ZCMiller's Avatar
Been trying to diagnose my troubles without any luck. I did notice if I cycled my key two or three times it seemed to smoke less. I may have also just imagined it.
ZCMiller is offline
post #4 of 7 Old 07-10-2013, 12:14 PM
ADMIN AND TECH
SCUFFY828's Avatar
injector wear , not that abnormal on cold start with a weak injector or two, possibly a weak ficm , but a quick test would answer that
ITS STOCK
SCUFFY828 is offline
post #5 of 7 Old 07-10-2013, 12:15 PM
taskforcefreddy's Avatar
FICM? You mentioned a lot of stuff but never mentioned anything about your FICM voltage.
taskforcefreddy is offline
post #6 of 7 Old 02-10-2014, 05:35 PM
same problem here 05 142k all stock with 8 new injs and ficm 4k later still have have a smoky cold 6.0
skeeterman is offline
post #7 of 7 Old 02-11-2014, 12:37 PM
Welcome to diesel trucks. This is normal on most of diesel engines.
JorgeCanek is offline
