It's not the FICM, what next? - Ford Powerstroke Diesel Forum
post #1 of 26 Old 07-04-2013, 10:37 AM Thread Starter
I've read so much about cold rough start issues that I'm getting confused!
I've been having the cold start being rough as some have here - and unless it's plugged in. I checked the FICM with a multimetre and at key on engine off it was reading 48v. At cranking it was about 46-47 and at cold idle was 45.6-45.7. This tells me the FICM is not my problem (I was surprised). I've read bits about the injectors possibly being the problem, but wonder if it might be the glowplug modulator? (I think that was what its called - found that online and read only one place that this could also be another issue)
thought? And thanks!
2004 6.0 F250 Crew Cab
ficm rebuilt, atlas 40 tune
egr delete, arp studs, head gasgets
hpop, turbo replaced
oilfieldguypaul is offline
post #2 of 26 Old 07-04-2013, 10:50 AM
The Silent Service
colo_dually's Avatar
Quoted: 16 Post(s)
Cold idle at 45.6-45.7v isn't near normal, and though it doesn't violate that 45v threashold - its about to come due for you. I wouldn't discount it being a factor just yet. (this assumes you didn't go with a 53v or 58v FICM.)
What is your fuel pressure right now, or do you not have a method yet to determine that (the updated spring [blue spring mod] doesn't mean you don't need to monitor that).
Further than that, could be something in tuning? So what file are you running, and are you running an FICM tune.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #3 of 26 Old 07-04-2013, 10:57 AM
BBBRRRRRTTTTT
powerstrokeshellback's Avatar
Quoted: 85 Post(s)
Feedback Score: 7 reviews
are your glow plugs working? how cold is it actually getting?
God bless America, the Constitution and the Second Amendment.
2016 F-250 Super Crew XLT 6.7L
2007 F-250 Super Cab XL 6.0L (sold)
powerstrokeshellback is offline
post #4 of 26 Old 07-04-2013, 10:58 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 958 Post(s)
Feedback Score: 6 reviews
The GPCM (glow plug control module) isn't very common to go out on our trucks. I looked into that when I had the same kind of issues you are having. I had to plug my truck in over night during the summer in order for it to start. It did indeed end up being my FICM that was bad, but my voltage dropped drastically during cranking so it was is to figure out.
Do you have access to a good scanner to pull codes and/or read somethings while you try to crank it?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #5 of 26 Old 07-04-2013, 11:01 AM Thread Starter
Thanks for being a downer in a way lol A lot of what you mentioned I don't know about honestly. Since I bought the truck I've done egr delete/head gaskets with studs as my only real work. Coming out of winter it was noticeably rough starting without being plugged in. Not sure what the fuel pressure is, and the FICM is factory I believe...48v probably? You've mentioned things I haven't read about yet unfortunately :/
post #6 of 26 Old 07-04-2013, 11:04 AM Thread Starter
I guess that's why there's not too much info regarding the glowplug mod. cool...Mine is exactly that; plug it in even in summer and it starts great, unplugged now it's just a bit rough, then rough driving until it warms up a bit. I don't have access to a scanner no, but I will try to get to my brother's (8 hour drive lol) he's a mechanic here...
post #7 of 26 Old 07-04-2013, 11:06 AM Thread Starter
I'm not sure how to check the plugs but will find out for sure. I thought those wouldn't generally be an issue yet (195 000 kms)
post #8 of 26 Old 07-04-2013, 11:07 AM
The Silent Service
Quoted: 16 Post(s)
Take some time to read through the monitoring and bullet proofing threads in my sig. I feel your FICM is due for replacement (or at least a new powersupply).
post #9 of 26 Old 07-04-2013, 11:09 AM Thread Starter
wiil do, and thanks. I guess I expected anything 45ish was still a good read...youtube vids were deceiving showing 27-29 v lol
post #10 of 26 Old 07-04-2013, 11:16 AM
The Silent Service
Quoted: 16 Post(s)
You start getting to that 45v area, and you start killing injectors.
I have watched a few of those 27v videos, and it scares me. No wonder the 6.0L has the reputation it has.
