Bulletproof EGR and Oil cooler question - Ford Powerstroke Diesel Forum
post #1 of 7 Old 07-03-2013, 08:20 PM Thread Starter
I'm looking at trading in my 1999 7.3 for a 2006 with a 6.0, the price is right it's a solid truck and worth the deal i can get IF it's had one of the aftermarket solutions done. And that is my question, is there a way to tell or identify if the truck has a BPD or othe aftermarket EGR valve, EGR cooler or BPD oil cooler? I have a 2004 6.0 also that i have bee through the whole EGR problem with. I had the EGR delete done on it which has worked great but it seems that is being frowned on now. I think if it has the "stock" EGR system it would probably be a deal breaker for me as paying for parts and laybor for the legal fix would just make the deal not worth it, it's a good deal but not $4,000+ good.
gparrow is offline
post #2 of 7 Old 07-03-2013, 09:05 PM
information regurgitator
NYC F-350's Avatar
Quoted: 49 Post(s)
I haven't heard of an aftermarket EGR valve..usually they are removed from the intake, a block off plate is installed and the valves are zip-tied to something.
You can easily tell if it has the BPD kit on it. Check right in front of the turbo. If you see a masterpiece of machine work with two 3/4 inch hoses coming off of it, it has it.
A BPD EGR cooler will be near impossible to tell from a stocker without taking it off....
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 7 Old 07-03-2013, 09:45 PM Thread Starter
thanks, i don't know why i put that about the EGR valve in there, i guess i've just been thinking about it to much today trying to make a decission. Ran a carfax on it earlier and came back branded salvage so deals off anyway. I have to say they did a nice job making it look good but i aint paying $15,000 for a 6.0 that has a salvage title.
gparrow is offline
post #4 of 7 Old 07-03-2013, 10:03 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
If you take the plastic cover that inbetween the grille and the radiator on top, you will clearly see the BPD oil cooler... Plus there will be a few 3/4 running past the radiator and behind the a/c condenser. Also, you should have a line tapped into the oil fill cap for the engine oil.
FYI- You can also spot head studs on the outside of the cylinder heads... Either cylinder head closest to the radiator and exhaust. You should see a stud coming out of the block with a nut over it. Stock has regular bolts.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #5 of 7 Old 07-03-2013, 10:09 PM Thread Starter
Thanks, studs were the first thing i checked because i knew what to look for but i don't know anything about the Coolers so could'nt tell if they were stock also or not.
gparrow is offline
post #6 of 7 Old 07-04-2013, 01:01 AM
NYC F-350's Avatar
Quoted: 49 Post(s)
Only if it has a bypass oil filtration.
Please
post #7 of 7 Old 07-04-2013, 01:16 AM
Quoted: 8 Post(s)
, I'm sorry. NYC F-350 is correct. Couldn't he take the oil filter cap off and verify there is no filter? BPD just came out with the kit that utilizes the factory filters, correct?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Tags
6.0 , egr , oil cooler
