VGT anti scream switch - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-03-2013, 04:13 PM Thread Starter
** THIS IS NOT A SMOKE SWITCH THREAD**
This isn't so much of a problem as it is a how to. As the name insinuates, I have a 2003 and it screams pretty loud. Loud enough that I have been getting negative attention from the gate guards at work.
As I understand, defeating the VGT will eliminate the screaming at idle. This would be useful as it would make the gate guards happy. There appears to be two wires, which one would I interrupt? Would I simply wire in a switch that keeps the circuit open for normal operation (ON) then breaks the circuit to defeat the VGT (OFF)?
If you can't tell, my electrical skills are such that I ask before doing the simplest of tasks.
Thanks.
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
post #2 of 12 Old 07-04-2013, 11:48 AM
Ordnance on coordinates
powerstrokeshellback's Avatar
Quoted: 53 Post(s)
Feedback Score: 7 reviews
i wouldnt alter my truck to appease gate guards.
2007 Ford F-250 XL 6.0L Powerstroke 4x4
God bless America, the Constitution and the Second Amendment.
Archoil gangbang - don't be the soggy biscuit
powerstrokeshellback is offline
post #3 of 12 Old 07-04-2013, 11:51 AM
RIP Cam!
Rattlesnake18's Avatar
Quoted: 823 Post(s)
Feedback Score: 6 reviews
I agree.
Also, what could the negative side effects be from doing this to your truck?
2004 F250 CC Lariat 4x4
BPD FICM, BPD billet water pump, BPD VK688 oil cooler kit, S&B CAI, MTW stage 2, TSD tunes, Auto Meter gauges, Edge CTS, Sinister coolant filter, Blue spring, 6.4 banjo bolts, Straight piped w/ 6" single mitre stack, Pro Comp leveling kit, 05-07 HD headlights, Xenon-Vision 5k HIDs, Fumoto block drain valves, ELC, High idle mod
Originally Posted by djmaguire View Post
I'm guessing that you didn't lose nearly as much as it appeared. Spills are like that. The last beer that I spilled was like a million ounces.
Rattlesnake18 is offline
post #4 of 12 Old 07-04-2013, 12:03 PM
The Silent Service
colo_dually's Avatar
Quoted: 10 Post(s)
If you are military, they have zero reason to be giving you any negative attention over the scream of the '03 whistle. Its like that stock, they can get over it.
Now for the negative, anything you do to have a cutout so to speak is going to have points of failure, which could cause a lot worse damage to the truck than annoying the gaurds.
Lets say you do this electronically, without a butterfly valve, just altering the VGT cycle. Most likely you'd create a overboost condition, or an excessive backpressure condition. Overboost, of course could cause a number of issues (boost leaks, boots blowing off, etc.). High exhaust pressure, and you could lift the exhaust valves enough to strike the pistons (same as a jake brake can).
I wouldn't alter this in the manner you are proposing. At any time you hit that switch by mistake, say on the interstate or when towing, and its hard to say how much damage you'd cause.
The only thing I know to deaden that whistle is a restrictive cat, and muffler. Your other option is swap to a later turbo, and have tunes written out to cover it.
2007 F-350 XLT 6.0L PSD Dually 'Jezebel'
TorqShift 4x4 CC/LB 4.30LS - Tow Boss Package
colo_dually is offline
post #5 of 12 Old 07-04-2013, 12:38 PM
HarvestingInternationally's Avatar
I would never alter my truck with possible damage to appease anyone especially if its stock
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #6 of 12 Old 07-04-2013, 03:10 PM
I have a "smoke switch" on my truck. I have used it a lot, not to smoke but to quiet the truck when I need to. I used a relay and an upfitter switch. Doesn't matter which wire you use. My worked perfect until my 03 turbo install.
Which brings me to this question are you sure you have a vgt turbo. The idea of the 03 turbo is that it isn't electronically controlled.
2006 White F350 CCLB 2WD
dowmace is offline
post #7 of 12 Old 07-04-2013, 03:12 PM
I have a good condition 06 turbo I'll trade you that would be quieter if you'd like.
dowmace is offline
post #8 of 12 Old 07-04-2013, 03:16 PM
ngaraiderman's Avatar
I would probably pull mine down into fist gear and really let them hear my straight pipe scream. Stupid guards.
ngaraiderman is offline
post #9 of 12 Old 07-04-2013, 03:17 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Not a good idea. This is a pcm output.
2001 to 2015 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 27 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #10 of 12 Old 07-04-2013, 03:27 PM
Funny a lot of people want to go the other way just to get back that kool turbo whistle.
They buy a 03 and refurbish it and install on the newer trucks.
Lord I shall lead them to the water but I will not try to make them drink
dannyboy950 is offline
