No Sync - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-01-2013, 11:18 PM Thread Starter
WDCDAVE's Avatar
No Sync
When in dought go to the pros.Ok so I bought another truck which makes about 16 F350 s in the fleet 9 are 6.0 so about the 4th one I bought the A/E marvalous tool saved me a half mil by now.I do love the 6.0 and have become well versus in taking them apart and fixing the bugs.This on is a 05 F-350 got for $1800 and was a no start.Hooked the A/E up no oil pressure so proceeded to do the oil cooler,ICP valve had a hole in both screens,egr delete.Checked all the fuse everthing good 48v on ficm,icp hits 900psi and climbs now,BUT have no ficm sync,so upon futher reading here and searching I changed the CPS,changed the ficm from running truck still no change,What I also get is ingnition open,and can bus error which I believe is a ground but double checked everywhere,firewall behind on fender chassis all good.The ficm sync got me stumped though were should I look to find this in the wiring harness ?as they all clicked good the second plug is for the injectors?Cmp &cps also do not sync?fuel is good oil pressure up there when cranking.Just really believe need sync on ficm to get to fire ,it is also a standard.Did have to replace starter any ideas would help Thanks
Made to be drivin hard.This is how I decided to stick with the 04-06 6.0
06 F-350 Lariat 4 in on 35s eagle eyes 248 k
06 Lariat Dually 367 k
05 XLT Super-cab fancy paint and 20 in rims 145k
05 XLT Dually kinda stock but have plans 288 km
99 F250 7.3 just a cool truck 185 k sold
09 F-150 King Ranch The cruiser
06 F-350 XLT 178 km
06 F-350 XL Super-cab 147km
01 F-350 XLT Deck Truck 06 front clip 288 KM 7.3
2010 F-350 Dually slightly modded bought at 58,000 pushing 259k
WDCDAVE is offline
post #2 of 6 Old 07-02-2013, 05:08 AM
jtaylor75's Avatar
yes, you do need FICM sync to start. I was fighting a no start issue for a while, it turned out to be a broke tone wheel on the crank. What i've learned is that even if your not getting a CKP signal then the computer with default and use the CMP singal for the RPM indication on the dash. The last thing i learned is that although I love me A/E sometimes it just dosn't have a high enough refresh rate to see whats going on. I had to use a buddy's IDS before i figured out what was going on. There are some tests out there somewhere where you can check the AC voltage that is generated from the CKP/CMP. There is also a test to check the ohms in the sensors as well. I'll see if i can find them somewhere.
06 CCSB FX4 Lariat
Studded and Deleted, Warren 190/100s, Barder Stage 4, Built Trans, AIS Water/Meth, S&B intake, 4 inch Exhaust
Next:
A fuel system
jtaylor75 is offline
post #3 of 6 Old 07-02-2013, 04:10 PM Thread Starter
WDCDAVE's Avatar
Ok just put fresh batteries in it still no sync checked grounds again and tryed the engine rpm it reads about 60-70 maybe the pcm will look at one on another truck see if its the same style as this one only has the 2 plugs to it,Thanks for the reply
06 F-350 XLT 178 km
WDCDAVE is offline
post #4 of 6 Old 07-04-2013, 09:46 PM Thread Starter
WDCDAVE's Avatar
With the a/e still no ficm sync also the crank and cam are not synced pulled the pcm plug looks like it was off before as there was dielectric grease on it (dont think thats factory not sure)Had a look at the cam sensor on pass side it looks like it is brand new and shinny black.So just wondering if anybody knows the pin outs on the cam and crank sensors at the ficm and pcm I think they should read 300 ckp ohms and 1000 ohms cmp.My understanding is they go from sensor to pcm to ficm.If the cmp signal is corrupt then you get no sync.What I have read is "Sync is totally dirived from the CKP sensor.It is possible to have no CMP sensor signal and still have sync and a RPM signal".I have a rpm signal but no ckp and cmp sync & ficm sync.This leads me to belive the crank sensor which was changed is bad or wiring issue. Any ideas??
06 F-350 XLT 178 km
WDCDAVE is offline
post #5 of 6 Old 07-13-2013, 06:04 PM Thread Starter
WDCDAVE's Avatar
going to change out wiring harness cannot seem to find any reading about how to test a harrness or pinout locatons
06 F-350 XLT 178 km
WDCDAVE is offline
post #6 of 6 Old 07-15-2013, 09:04 PM Thread Starter
WDCDAVE's Avatar
Shes running and purrs like a top switched out the harness and presto
06 F-350 XLT 178 km
WDCDAVE is offline
