Replacement Heads from Ford - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-01-2013, 07:33 PM Thread Starter
Gus_hauler's Avatar
Anyone out there ever replace their heads with the reman kit from Ford? I picked up my new heads this weekend and when I put them on tonight I noticed that a lot of the old bolt holes are not there on the new heads where the old rocket-box would bolt down onto. For example, on the exhaust side of the head, on the outside of the rocker box, there are the head bolts, then the hole for the glow plugs, and then a hole for the rocker-box bolts. On the the new heads though, there is no thread cut for those rocker box bolts to thread into.
Anyone else notice this?
I guess it isn't too critical though. I suppose the 210 ft.lbs. of force on the head studs will be enough to hold that rocker box down.
2004 F-350 Crew Cab LB Dually
"Longhorn Hauler" edition
New Heads!
ARP Studs
Banks Six-Gun with PowerPDA (For gauges only)
EGR Delete from IPR
Rotella ELC
New Turbo from Garrett
Gus_hauler is offline
post #2 of 6 Old 07-01-2013, 07:53 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
the new heads don't have them it is completely ok and normal.
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #3 of 6 Old 07-01-2013, 07:53 PM
Bump To Pass!!
toren302's Avatar
Quoted: 1793 Post(s)
Yep this is normal. There arent any holes anymore. Guess they figured out the head bolts/studs are enough. The last customer rig I did we used new ford heads and they were the same.
Originally Posted by kaya View Post
If you follow the sequence to diagnose their issues, and repair them correctly, they're a great engine.
You get what you put in
toren302 is offline
post #4 of 6 Old 07-01-2013, 07:54 PM
Bump To Pass!!
toren302's Avatar
AHHHHHHH!!!! Treeed again by Jug!!!
toren302 is offline
post #5 of 6 Old 07-01-2013, 08:40 PM Thread Starter
Gus_hauler's Avatar
Thanks all. I must have stared at them for 20 minutes thinking I had them on backward, or upside down or something. I finally figured it must be the new design.
I got my new heads in place, and valve rockers in. Then I realized I forgot to take some of the bolts off my old heads before I turned them in. Doh! Gotta call the dealership tomorrow to see if they've shipped them back yet. Hopefully not. I really need the plugs for the back side of the heads where the fuel lines would go if they were reversed.
New Heads!
ARP Studs
EGR Delete from IPR
Rotella ELC
post #6 of 6 Old 07-01-2013, 08:40 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Hahahaha got ya!!!
A/C ASW A/W WINGS
