HP Oil leak - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-01-2013, 09:57 AM Thread Starter
HP Oil leak
Brief history
2005 F250, 150k
I had a crank no start condition. ICP reading 310-325.
I tore the motor down to replace the head gaskets, and fix my HP oil leak.
I think ive found it.
Is this the culprit?
There was an oring like this on the strand pipe as well
jesterjames is offline
post #2 of 6 Old 07-01-2013, 10:01 AM
information regurgitator
NYC F-350's Avatar
Quoted: 54 Post(s)
Most likely, yes.
You should replace the standdpipes and dummy plugs as part of doing the headgaskets anyway. If you haven't already changed out the STC fitting on the HPOP, now is the time to do that as well.
Please
You could save the life of a sick child
NYC F-350 is offline
post #3 of 6 Old 07-01-2013, 10:13 AM Thread Starter
I was hoping so, Orings probably dont like seats that arent flat.
Im gonna do the STC fitting, Blue spring update, Turbo oil Feed, Oil drain, Standpipes, dummy plugs, injector orings, egr delete, and arp head steads.
post #4 of 6 Old 07-03-2013, 06:11 PM
I don't think that is your problem. I have an 04 so its a different HPOP however the stand pipes and dummy plugs are the same. I'm chasing a no hot start issue right now. I pulled my stand pipes and dummy plugs which were the upgrades and they looked just like that. I replaced them with new ones as I had them anyways. Still the same issue. I'm a hydraulics guy for the Marine Corps. I agree that the white backing ring SHOULD match up and sit level however in this case, I don't think that is causing you leak. I think everyone that has the revised pipes and plugs, their will look just like that.
ryclef331 is offline
post #5 of 6 Old 07-03-2013, 08:09 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Originally Posted by jesterjames View Post
Brief history
2005 F250, 150k
That is not your problem there is no cut or worn oring as they are the updated dummy plugs and if the stand pipe have the same Teflon ring they are updated too! did you check your t-fitting?
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
post #6 of 6 Old 07-03-2013, 09:14 PM
twoicebergs's Avatar
Quoted: 47 Post(s)
The teflon ring is split on purpose to allow it to fit in the grove. It acts as support for the o-ring to prevent pinching and blow-out.
Here is one I just pulled out of the bag for the picture. If you over squeeze it, it will climb on top as in your picture.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
