pretty sure i toasted the turbo - Ford Powerstroke Diesel Forum
post #1 of 17 Old 06-30-2013, 12:16 PM Thread Starter
06fordstroker's Avatar
Last night when around a turn got on it alittle had 5-8 lbs of boost and then bang, lost boost and white smoke out the exhaust, took intercooler pipe and air intake off and compressor wheel is intact and spins but had oil all over it. truck makes a horrible metal grinding noise like something in the turbo is broke and bouncing around. would it be a bearing, broken shaft or maybe a unison ring broke?? just looking for some help, truck is80% tore down already
Adam
06 F-250 6.0 powerstroke
ext.cab, sb, 4x4
tinted windows and air bags in the rear
sct livewire!!!-10/23/12
edge insight cts- 7/23/12
Looney Tuned!!!- 1/11/13
4in Diamond Eye Exhaust - 2/22/13
03 turbo installed - 7/7/13
06fordstroker is offline
post #2 of 17 Old 06-30-2013, 12:21 PM
Njstroker91's Avatar
Pull out the turbo and look do you have oil in your down pipe?
Sent from AutoGuide.com App
2006 f350 eclb 6 speed, powermax, billet compressor wheel, valair dual disk, 4in to 6in cat stack, afe magnum force stage 2, airdog 150, xdp sump, zoodad mod, sinister coolant filter, gauges egt oil temp and fuel pressure, cfm carbon fiber and metal cold side tub, blue spring, bpd ficm, moto metal 959 18x9 wrapped with cooper at3, custom shift knob from lilpooh, Polk audio all the way around, dashboss for monitoring
Njstroker91 is offline
post #3 of 17 Old 06-30-2013, 12:26 PM Thread Starter
i will check here in a little while. it was all of a sudden event. defiantly sounds like something is hitting on the exhaust side of the turbo.
Adam
ext.cab, sb, 4x4
post #4 of 17 Old 06-30-2013, 12:30 PM
Good possibilities don't here much about shafts breaking but it could be might as well dig in pull it out and check it out. I had my stock charger break a vein off I got lucky it didn't hit the turbine.
post #5 of 17 Old 06-30-2013, 12:32 PM
Make sure it's not a blown boot start simply but the way you are saying sounds like its making a pretty good noise
post #6 of 17 Old 06-30-2013, 12:42 PM Thread Starter
yea its not a blown boot, the noise was god awful like something spinning out of blance inside the turbo. but why would it go out all of sudden, its a reman turbo, and it was put on before i bought the truck a year and 7 days ago!? i got my hands on a 03 to put back in though for $300 bucks!!
Adam
ext.cab, sb, 4x4
post #7 of 17 Old 06-30-2013, 12:46 PM
Cowgirl forever!!!
SCPowerstrokecowgirl's Avatar
Quoted: 7 Post(s)
dont sound good.good luck w the fix
Jess
01 F350 Crew Cab 4x4 7.3 once again!!
MBRP 4'' Turbo Back and Chrome
05 Grille
Carolina Powerstroke Assocation member
LIFE IS TO SHORT SO RIDE A FAST HORSE!
SCPowerstrokecowgirl is offline
post #8 of 17 Old 06-30-2013, 12:47 PM
Not sure man
post #9 of 17 Old 06-30-2013, 02:23 PM Thread Starter
well im into futher now and gotthe downpipe apart its black if i put my fingers in there. i cant get the oil feed tube off at the bottom. but it seems like it wasnt feeding it oil, im having trouble breaking loos the clamp behind the turbo!!!
Adam
ext.cab, sb, 4x4
post #10 of 17 Old 07-01-2013, 06:35 AM Thread Starter
is the orings for the oil feed and drain tube the same for a 03 turb? im replacing my 06 turbo with an 03, and didnt knw if there was a difference in the gasket and seals for the oil feed and drain tubes.
Adam
ext.cab, sb, 4x4
