2005 F250 Major Update - Ford Powerstroke Diesel Forum
post #1 of 46 Old 06-29-2013, 01:29 PM Thread Starter
This is my first diesel truck and I am definitely happy with it. Pulls everything I've tried without a problem and very smoothly as well. I guess the only problem was I didn't do enough research when I bought it to discover all the 6.0 problems or maybe I could have prevented this problem. Diagnosed the wrench light to a clogged oil cooler with ECT 194 and EOT 220 so figured I should just cry once and get some other stuff done at the same time. I don't like bringing my truck in to a shop and couldn't afford the dealer anyway so I am hoping I can do all this myself. I've spent quite a few hours reading up on replacing the cooler and I think I can get it done, it's just going to take some time. I put together a list of everything I plan to get done and was hoping you guy could go over it to make sure I'm not missing anything. It's attached as a Excel file so if you can't open it I'll try to make it as a forum post instead.
Here is what I plan to do, in order.
Coolant Flush
Install DieselSite Coolant Filter
Replace Oil Cooler
Clean Turbo
Replace Fuel Pressure Spring
Re-route CCV
Change Transfer Case Fluid
Change Transmission Fluid
Change various filters that I never got around to.
Looking at that list again it looks like I at least have it going from hard to easy . Thank you to anyone that helps!
Full Draw is offline
post #2 of 46 Old 06-29-2013, 01:43 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Might also look into a coolant filter. I think you will be suprised at reeley how user freindly the 6.0 is for working on. Something that will make your life easier is a top creeper. Got mine from SEARS and was well worth the cash
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 46 Old 06-29-2013, 01:46 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 276 Post(s)
If your going to have the turbo off, then you might want to investigate and maybe have ready the updated HPO STC fitting
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #4 of 46 Old 06-29-2013, 02:15 PM Thread Starter
The coolant filter is on the parts list, forgot to put it in the post. Will look into the HPO STC fitting.
post #5 of 46 Old 06-29-2013, 02:17 PM
Quoted: 276 Post(s)
How about an EGR delete too if your state doesnt have diesel emissions
post #6 of 46 Old 07-01-2013, 09:29 AM Thread Starter
I had thought about doing an EGR delete. If what I read was correct I'd have to run tunes to get rid of the CEL messages. I don't want to start messing with that. Only reason I would, would be to gain a few MPG's but from what I've read it doesn't do much/isn't worth the cost. I have plenty of power and get 16-17MPG highway, 10-11 towing so I am not sure how much better that could get. While I don't plan on selling my truck for quite a while, I'd rather not screw the next guy by having it deleted.
post #7 of 46 Old 07-01-2013, 09:38 AM
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
Are you going back with an OEM egr cooler or going with the bulletproof cooler?
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #8 of 46 Old 07-01-2013, 02:50 PM Thread Starter
Was hoping I didn't have to replace it. If I do I would go back to OEM, I can't afford the BPD cooler.
post #9 of 46 Old 07-01-2013, 03:00 PM
Quoted: 276 Post(s)
Keep in mind... I have seen several members tell their tales of replacing an oil cooler only to have it clog again a short time later, and continued to go through that pain 2 & 3 times right in a row. At, what, about 400-500 bucks a pop plus your time and labor, hind site might say, shoulda just bulletproofed and forgot about it. I'm not trying to sell you something, but as a buyer of their product, it was and still is so worth the money for peace of mind. But what it comes down to is... Your truck, your budget, your choice, and I hope it works out for you
post #10 of 46 Old 07-01-2013, 03:02 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
^^^^agree. I thought about this long and hard and I knew with my luck Id clog up a brand new cooler. BPD FOR DA WIN!!!
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
