6.0 hydro locked. Pls help - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-29-2013, 02:17 PM Thread Starter
I have a 04 6.0. I replaced the #5 injector in it and it ran fine for 2 weeks. Well one day why'll driving it hydro locked. I imediately pulled the injector I installed and found the copper o-ring broke in half. I replaced o-rings and put everything back together. Know my question. Can I start the truck and let the fuel burn out or do I need to pull the glow plug and pump it out? Pls someone that has done this let me know.
Roughneck88 is offline
post #2 of 5 Old 06-29-2013, 02:53 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
You can turn the crankshaft by hand with the use of a ratchet etc. If it turns completely at least two revolutions you are fine. Over time the fuel should leak through the ring gaps and drain into oil pan. But not always. I would be doing a oil change.
Did you blow out the bolt hole for the injector hold down bolt? They can fill with oil and the bolt will not go all the way down when torqueing.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #3 of 5 Old 06-29-2013, 05:34 PM Thread Starter
Yes I did blow out the hold down holes. If I can rotate it 2 full times how long should I wait to change the oil? An hour after I run, or a couple days?
post #4 of 5 Old 06-30-2013, 08:35 AM
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
Is there more on the dipstick ?? If it is up I would change it, diesel is a poor lubricant.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
post #5 of 5 Old 06-30-2013, 08:36 AM
mhatlen's Avatar
Quoted: 449 Post(s)
Garage
Depends how much is in there I would run it to make sure it's fixed then change
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
