Oil temp problems. I need help im so confused - Ford Powerstroke Diesel Forum
post #1 of 19 Old 06-29-2013, 12:52 PM Thread Starter
Dizzydd101's Avatar
I live in Texas so its pretty hot outside but I have a bpd oil cooler and radiator along with their ficm. im running rotella oil with a wix filter. my oil temps are getting to 225 where at coolant stays around 200.
Dizzydd101 is offline
post #2 of 19 Old 06-29-2013, 01:51 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Im working with a bit less than those temps myself and have also read some other post on here of guys with the same set up and issues. Basicly what it seems to narrow down to is make sure you dont have to much junk in front of your radiators (lights,tires,chains bumpers etc....) and one guy actull had to increase the gap between his oil cooler and the radiator and that seemed to fix his issues.
Im changing out my grill as soon as the big brown van drops it off. Also have you looked into the broom fan test? And the manual fan control?
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #3 of 19 Old 06-29-2013, 01:58 PM Thread Starter
Dizzydd101's Avatar
I have stock front end with the stock grill. broom test? and how do u like ur php atlas 40 tune kinnisoj?
post #4 of 19 Old 06-29-2013, 01:59 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 557 Post(s)
Garage
Dump the Wix filter for one. The coolant temp should be around 194* it may be because it's hot out but that is where it should be. If it's been in a long time may be a good idea to install a new thermostat. Use ONLY Motorcraft thermostat and filters.
Like stated above check the radiator and clean as necessary.
2006 F250 LARIAT CCSB 4X4
7" Icon/Carli Lift
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
4" SS exhaust
58K Miles on it
2000 Watts of McIntosh Bliss
mhatlen is offline
post #5 of 19 Old 06-29-2013, 02:02 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 276 Post(s)
Which BPD oil cooler are you running? The full setup with remote oil filter or the setup which retains the OEM filter?
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #6 of 19 Old 06-29-2013, 02:04 PM
Quoted: 276 Post(s)
I had spoken to BPD at one point about oil temps and they stated up to 250 is acceptable, and that coincides with Ford because that is where the engine will defuel
post #7 of 19 Old 06-29-2013, 02:08 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Just do a search for broom test, you'll love it. As far as the Atlas 40 I liked the Atlas 80 ALOT more but with pulling loads over the mountains the egt's would become a issue. I thought about fighting them with water/ meth system and a upgraded inter cooler but cash won out and I went the cheaper route. The atlas 40 is still a big improvement over stock but the atlas 80 had me spoiled...
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #8 of 19 Old 06-29-2013, 02:11 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
agree 100%^^^^
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 19 Old 06-29-2013, 02:35 PM
Quoted: 276 Post(s)
BTW, can somebody please get this broom fan test formatted differently, I want to see this so bad, sounds hilarious but aparently it works
post #10 of 19 Old 06-29-2013, 02:53 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
BROOM/FAN TEST-
Its on the second page sais movie.avi??? something like that....
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
