Head Nut Torque Extension - Ford Powerstroke Diesel Forum
post #1 of 1 Old 06-28-2013, 09:30 PM Thread Starter
Gus_hauler's Avatar
Hey all, just wanted to share something. I was watching some youtube videos about replacing the head bolts and one video in particular strongly recommended picking up a tool made by Snap-On that is an extension made to torque down the driver's side rear bolt/nut. So I looked it up, and I knew it would be pricy, but my eyes still bugged out a bit when I saw the price:
SRD35, Torque Adaptor, Diesel Head Bolt, 6.0L Power Stroke Engines
Then I remembered something, I had a old 1/2" swivel that had broken on me. And, I had a small piece thick bar-stock. So I cut the swivel down and 10 minutes later had my own version of this extension.
(pictures attached)
After I was done something occurred to me that wasn't mentioned in the person's youtube video. Since this extension is lengthening the torque wrench, the torque measurement would be off. Surprisingly, when I searched google for some documentation on how to calculate the new torque setting, I found a TON of data. If you just search for "torque wrench extension calculation" you will get a lot of sites that calculate the new setting for you.
This is a good one:
Extensions Calculator Support Library Van F Belknap Company
ID:	131618   Click image for larger version
2004 F-350 Crew Cab LB Dually
"Longhorn Hauler" edition
New Heads!
ARP Studs
Banks Six-Gun with PowerPDA (For gauges only)
EGR Delete from IPR
Rotella ELC
New Turbo from Garrett
Gus_hauler is offline
