Cooling Fan Question - Ford Powerstroke Diesel Forum
post #1 of 86 Old 06-27-2013, 08:06 PM Thread Starter
DMc
Quoted: 209 Post(s)
My truck has been running hotter than normal when towing. ECT has reached 225 and EOT has reached 235. I've tried a lot of different things but no luck yet and I was wondering about the fan. I know it takes a few different things into account to determine fan speed but generally speaking I will start to hear it wind up around 216 to 218 ECT. It will run for 5 seconds or less and then wind back down. This doesn't really seem to lower the temps, just stalls them for a bit. The temps continue to climb until ECT levels off at 225 and EOT levels off at 235. The whole time the fan is cycling on for a few seconds and then back off. After a minute or so it will cycle back on again. High temps aside, does anyone else's fan sound like this? It seems to me it should come on and stay on for a while until the thing cools off. It never loses a drop of coolant.
The truck is a stock early 04 w/ Edge Insight and I've already tried;
Reverse Flush
Restore/Restore Plus Flush
Switched to ELC
Added coolant filter
Replaced the thermostat
Replaced the oil cooler
Replaced the EGR cooler
Checked radiator for obstructions in the fins
Checked water pump for impeller damage
I thought maybe I'd try throwing a fan clutch at it and see what happens so any insight into what others hear their fan doing would be great. I'm also open to any other thoughts anyone may have since I'm about out of ideas.
Thanks!
DMc is offline
post #2 of 86 Old 06-27-2013, 10:42 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
You should test your fan clutch with a broom! BROOM/FAN TEST- still makes me laugh!
Have you checked your fan wiring harness? They are know to cause problems and is an easy fix. Next time this is happening I would try and pull over and wiggle the wires around to see if you can keep the fan on that way.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 86 Old 06-28-2013, 04:47 AM
I have a 2005 F250 King Ranch diesel with over 380,000 miles, original engine, my air condition stops cooling when stuck at idle for 15 minutes or so, gets cold again when moving and AC turned off for 5 minutes. Fan comes on for maybe a minute or less. I was gonna put a fan clutch on, but don't want to start just throwing parts at it. Any help would be appreciated. Thanks, Earl
hofftemp is offline
post #4 of 86 Old 06-28-2013, 05:54 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Check out the manual fan switch. Probably not the 100% cure for the problem but it will give you control over the fan if needed.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #5 of 86 Old 06-28-2013, 06:07 AM
OK, thanks, I'll try that. The temp needle shows very little movement, I can set the bully dog guage to show temp, what should the normal temp be?
hofftemp is offline
post #6 of 86 Old 06-28-2013, 01:53 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
Check out the stickie-monitoring the 6.0, great read and full of info. As far as temp, mine runs from 188-205 depending on the temp's
,edge turbo timer
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #7 of 86 Old 06-28-2013, 02:08 PM
Unhappy
what is the "stickie-monitoring"?
hofftemp is offline
post #8 of 86 Old 06-28-2013, 03:03 PM
Sinister Diesel Sucks!!!
michaelaiman's Avatar
Quoted: 276 Post(s)
I was seeing some high temps this past weekend on the trip home from Maine pulling a small 5X8 enclosed with a range, water heater, tools, and luggage in it, and three rather large Americans in the truck, yes, that includes myself. Low 90s ambient and I was seeing 212*-215* on the ECT and 215*-220* on the EOT. Any idle time, it would quickly return to normal, but as soon as I would hit highway, it would go right back to those temps. I can however report that Coolant pressure, was always below 10 PSI. I like you suspect these temps are too high for such a light load, and my first suspect is the fan clutch wiring. So as soon as I get a chance to look at it, thats where I'm headed
03 F350 SD 6.0 PSD FX4 XLT CC LB SRW FOR SALE!!
To see why you should avoid Sinister Diesel, visit these threads:
michaelaiman is offline
post #9 of 86 Old 06-28-2013, 03:05 PM
Quoted: 276 Post(s)
P.S. Sticky: monitoring the 6.0....Write Up: Monitoring the 6.0L PSD.
post #10 of 86 Old 06-28-2013, 05:04 PM Thread Starter
DMc
Quoted: 209 Post(s)
OK, I tried the broom test (unless it's actually a Powerstroke.org initiation ritual just to see who will actually do it in which case I did NOT do the broom test)! With the engine at operating temp and at idle I can easily stop the fan just like ljones video. At idle with the A/C on, same results. High idle on but no A/C, same results. High idle on and A/C on, the fan is noticeably louder and I can't stop it. Now for the $64,000 question..... What does this mean? Should the clutch engage anytime the A/C is on? Haven't had a chance to remove the shroud and look at the fan wiring yet but it's on my list for tomorrow.
DMc is offline
