what else do i need - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-26-2013, 07:41 PM Thread Starter
Lightbulb what else do i need
ok so i have an 03 f250 6.0 with a 5in to 7in tip exhaust straight out of the turbo. i am looking to fix the "6.0 problem" my friend told me that head studs only need to be replaced if you mess things up but since mine runs fine i was wondering if i could prevent getting head studs my getting this air intake and sinister diesel egr kit? would i need anything else. i plan on doing the work myself. also when complete i am going to take it in to get a 3 tune sct tuner. gas. tow/daily. smoke(off road only). please let me know if you found a better kit than this one or any thing else. i am getting this intake though because my uncle has a brand new one in his garage free
air intake
http://www.summitracing.com/parts/ai...ty?prefilter=1
egr kit
Sinister Diesel EGR Valve & Cooler Delete 03-07 6.0L Ford Powerstroke
last question will i need higher hp injectors?
thanks for the help
ddlwfo94 is offline
post #2 of 5 Old 06-26-2013, 08:12 PM Thread Starter
or should i get one of these kits with a sct tuner which one would be better for what i am looking for it is a $200 price difference
sinister diesel $649
Sinister EGR Delete Kit - SCT Tuner Combo Ford 6.0l Powerstroke
performance machining $480
Performance Machine | 6.0L Powerstroke EGR Cooler & Valve Delete Kit with Up-pipe - 60LEGRWP
ddlwfo94 is offline
post #3 of 5 Old 06-26-2013, 10:27 PM
Fill it up again Dummy
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
Installing a aftermarket air filter assy is a bad idea. It will not filter near as well as the Donaldson OEM unit the truck came with. There is no HP gain whatsoever.
The head studs are necessary when you tune the engine at a certain point. Some tunes are safe with the stock head bolts. SCT with the SRL is a tune that can be used w/o studs.
2006 F250 LARIAT CCSB 4X4
ARP Studs, O-Ringed Heads
X4 PHP 65 HP Custom Tow Tune
Atlas40
CAT EC-1 Coolant, IPR Coolant filter
BPD Waterpump
Fass-125 to a Adjustable Pressure Reg.
Turbo-back SS 4" pipe, Corsa Muffler -7" Tip
6.4 starter, DC Power 270 w/ AGM regulator
Die Hard Platinum AGM all 2/0 Cables
Fabtech Radius Arms
7" lift w: Icon Progressive Coil Springs
2008 up Carli/Deaver rear springs
2000 Watts of McIntosh Bliss
All riding on some Fatty-Daddy 38/15.50/18 Toyo's
mhatlen is offline
post #4 of 5 Old 06-26-2013, 10:40 PM Thread Starter
which kit would you choose the sinister or performance machine
ddlwfo94 is offline
post #5 of 5 Old 06-26-2013, 11:05 PM
mhatlen's Avatar
Quoted: 448 Post(s)
Garage
Sinister is good quality stuff but either one here should be fine.
I have no experience with either one since I live in California and have to keep egr on the truck .
Someone will chime in I'm sure.
Atlas40
BPD Waterpump
Fabtech Radius Arms
mhatlen is offline
