CHRA help - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-26-2013, 02:18 AM Thread Starter
CHRA help
So I found my main oil leak (turbine side seal) but have notice cleaning the CHRA that another leak is from the shaft of the Unison Ring actuator. I removed the shaft and found what appears to be a grove for an o-ring. Anyone know if there is supposed to be a seal in this location? Part number? I don't think its included with the rebuild kit. Late model 06. Thanks.
hdjetmech is offline
post #2 of 2 Old 06-28-2013, 04:48 PM Thread Starter
Update. There is no seal, interference fit. Finished everything today, road test pass. Time will tell if the oil burn returns.
2006 F-350 CC FX4 DRW:
BPD Cold Weather Oil Cooler w/OEM Filter, BPD Water Pump,
BPD EGR Cooling Tube, STC Fitting, Blue Spring,
Edge CTS w/EGT, SCT FS3, ARP's, UCF Machine Heads.
Red-Head
