Turbo going out? Sound clip from the tailpipe - Ford Powerstroke Diesel Forum
post #1 of 7 Old 06-25-2013, 07:53 PM Thread Starter
HillbillyDeluxe39's Avatar
2007 6.0 5" exhaust, grinding sound from tail pipe, also a high pitch whistle passenger side rear of engine.
IMG_1548.mp4 Video by HillbillyDeluxe39 | Photobucket
Starts around 0:22
IMG_1541.mp4 Video by HillbillyDeluxe39 | Photobucket
Had it at the dealer twice already under warranty, they claim its the after market intake and exhaust. Sounds to me like the thrust bearing has gone out... thoughts?
2000 F250 CCSB 4x4
6637, Tony Wildman Tunes, HPx, Terminator HPOP, 6.0 IC, WW, 285/75R16 Hankook Dynapro AT's
HillbillyDeluxe39 is offline
post #2 of 7 Old 06-27-2013, 04:37 PM
Could be a broken baffle in the muffler. What type muffler do you have?
2006 F350 lariat 4x4, S&b intake, 4" exhaust, 03 turbo, sinister egr cooler, BPD remote oil cooler, BPD FICM, stc and dummys, diablowsport program, 5" lift, 35's, led fog bar, flatbed welding rig. SOLD. Went the darkside, 2014 ram 3500 daully.
gblauf is offline
post #3 of 7 Old 06-27-2013, 08:37 PM Thread Starter
Muffler is a perforated tube, Ford says its a cracked up pipe. Checked it today and yes the passenger side up pipe accordion thing is cracked, explains the whistle. It doesn't explain the can of rocks sound coming from the exhaust. They want $1300 to fix the up pipe before further diagnosis. Turbo is under warranty but not the pipes, got 3000 more miles before its out.
Plan was to do an EGR delete with up pipe after warranty was out, they said it would void it. So..... not sure what to do at this point.
2000 F250 CCSB 4x4
post #4 of 7 Old 06-27-2013, 08:43 PM Thread Starter
Clip from under the truck next to the pipe.
IMG_1550.mp4 Video by HillbillyDeluxe39 | Photobucket
2000 F250 CCSB 4x4
post #5 of 7 Old 06-27-2013, 08:51 PM
twoicebergs's Avatar
Quoted: 46 Post(s)
Better quality on the last one; thanks!
I really didn't hear the rattle. It sounded pretty much like a leaking exhaust. Whistle and a bit of rumble.
Frank
2007 F-250 Lariat Crew. MBM 190/50s,
KC-68 Stage 3 Turbo,
DashBoss/F/P, and a few other goodies
Stiction Problems - Fix it yourself! -
Want to modify your injectors DIY -
Working for Toys
twoicebergs is offline
post #6 of 7 Old 06-27-2013, 09:00 PM Thread Starter
In the first clip the engine is off, between 0:04 and 0:10 if you turn the volume way up you can here it pretty good, not as good as in person but that's my buddys iphone for ya. The slip joint is loose but I don't see it rattling after the engine has been shut off. We are going to pull the turbo and have a look.
2000 F250 CCSB 4x4
post #7 of 7 Old 06-28-2013, 06:07 PM
Strokergonebroke's Avatar
sound to me like mine when the up-pipe wasnt seated just perfectly to the turbo and the flang bolts....took us and entire 20 mins and few salor words and the problem was fixed.
even if it wasnt before its only a hr tops and it could be your problem.
2004 6.0...studded,sinister coolant filter,updated turbo lines,oil cooler,fuel spring,egr delete, 6in lift, 37 military tires, looney'd and podded.
Strokergonebroke is offline
