blue spring upgrade - Ford Powerstroke Diesel Forum
post #1 of 12 Old 06-25-2013, 07:40 PM Thread Starter
dlrobert95's Avatar
blue spring upgrade
When doing the blue spring upgrade, must you buy the $70 kit with the new housing and the whole works, or will the $30 spring and o-ring only kit suffice?
Thanks for your opinions!
dlrobert95 is offline
post #2 of 12 Old 06-25-2013, 08:04 PM
Term3's Avatar
Quoted: 2 Post(s)
Just the spring and the funny shaped O-ring. Heck, I've even used the same O-ring on occasion with no leaks. Also never had to take anything apart except the cover for the spring. Never felt like loosing coolant for no reason. LOL
Sent from AutoGuide.com App
SCT, no studs...yet, Dual OEM intake air filter housings, Banks intercooler & intake elbow, Banks exhaust system, Windrunner ported intake manifold, Bullet Proof Diesel remote oil cooler & thermostat, AirDog2 (plus a couple spares), Power steering filter (Amsoil dual-bypass), MagTec deep ATF pan, Electric oil pre-lub pump, Dakota Digital gauges.
Term3 is offline
post #3 of 12 Old 06-25-2013, 08:10 PM
mustangmike6996's Avatar
I bought the whole kit. I know ppl here have done just the partial kit but you have to be careful with the housing when removing it.
mustangmike6996 is offline
post #4 of 12 Old 06-25-2013, 08:47 PM
JustinOOO9's Avatar
Quoted: 521 Post(s)
Garage
if you dn't wanna spend $70 don't unless your housing is cracked or you just like shiny stuff... I regretted buying the one from ford because the new housing is still sitting in my pass door cubby lol....
Never really noticed a difference though but im still pretty young to the diesel world and figured I'd do what ppl recommended that had more experience etc...
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #5 of 12 Old 06-25-2013, 10:27 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
This mod basically insures you that a weak spring isn't going to cost you thousands of dollars in fuel injector repair. Some have noticed that to achieve optimal performance you need a regulated return system and turn the fuel down to around 52-55 psi. Without regulating a healthy fuel system its normally around 65psi. But this is a whole different topic.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #6 of 12 Old 06-25-2013, 10:46 PM
ngaraiderman's Avatar
i also only used the new oring and the spring only. the rest is in the tool box incase it is needed later
ngaraiderman is offline
post #7 of 12 Old 06-25-2013, 10:51 PM
ChrisSalyer's Avatar
I was also curious about the difference between the kits, I guess I'll buy the spring and keyhole shaped O-ring instead of the complete kit
ChrisSalyer is offline
post #8 of 12 Old 06-26-2013, 10:47 AM Thread Starter
dlrobert95's Avatar
Thanks guys! Ill just get the spring only kit and be very careful removing the original.
post #9 of 12 Old 06-27-2013, 05:25 PM
strokethis1121's Avatar
Red face number 1 did take a silence for morgan wild man my deepest condolences
where do u get the blue spring havnt really spent to much time looking for it, anything to help that navister drink better and last lol. praise krishna for morgan what a beautiful girl
strokethis1121 is offline
post #10 of 12 Old 06-27-2013, 05:32 PM
Quoted: 8 Post(s)
This is the full kit from BulletProof Diesel...
Fuel Pressure Regulator Kit, Upgraded Spring, Ford 6.0L
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
