Turbo Issue - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-25-2013, 02:17 PM Thread Starter
dieselforce's Avatar
Turbo Issue
I have a 2005 F250 with the 6.0L it has 134,000 miles on it. The truck has been running really good until this past weekend.
We bought a 28ft travel trailer that weighs about 7500 to 8000lbs when it is fully loaded out, we where towing it about a 100 miles or so and as I hit hills the transmission would downshift and the RPMs would hit about 2500 then the turbo boost started hitting 20 to 30 PSI with a lot of black smoke coming out of the exhaust. About halfway into our trip the boot popped off the intake or pressure side of the turbo and wouldn't stay on once the pressure started building up. I had to tow the truck to a repair shop where they replaced the boot and hooked it up to a tester and said I was all good.
The rest of the trip though the RPMs would spike and the boost would run really high. we just brought it into a dealer and the checked it over and said the boot was good and nothing causing pressure issues but the boost was running really high and they were surprised we made it back. They recommended tearing the turbo apart and cleaning it for about 400.00 but if that didn't work I might need a new turbo.
I guess I am wondering if this sounds right or if anyone has any suggestions on what to do next? Thank you in advance
dieselforce is offline
post #2 of 5 Old 06-25-2013, 06:46 PM
7.34ever's Avatar
Quoted: 2 Post(s)
Feedback Score: 9 reviews
Yes, clean it. No, don't pay $400. While taken apart for cleaning you may find that you do need a new one but you don't need the dealer's $400 bill to prove it. Is there any other org member near you that could assist?
12TH Man
Live in WA or OR??? Check out these links.
7.34ever is offline
post #3 of 5 Old 06-29-2013, 07:49 PM Thread Starter
Got the Turbo cleaned and everything seemed to be good in the turbo, hoping that's all it needed.
A friend of mine who works on diesels said it might of been from the previous owner who was running a multi stage programmer without upgrading the egr valve or cooler. He was saying that they can clog the stock ones up which causes the turbo to get gummed up and dirty. Does this sound right?
post #4 of 5 Old 06-30-2013, 10:46 AM
7.34ever's Avatar
Quoted: 2 Post(s)
The 6oh egr valves and coolers get plugged up from every day use no matter the brand. Delete it and be done
12TH Man
7.34ever is offline
post #5 of 5 Old 07-11-2013, 06:42 AM Thread Starter
How much work is it to put a delete on it? Is it a easier job or pretty time consuming?
