where to start?! - Ford Powerstroke Diesel Forum
post #1 of 17 Old 06-24-2013, 06:32 PM Thread Starter
BC stroker's Avatar
where to start?!
Havent posted for a while, but.. Bought a new truck last week. 04 6.0 auto, 160kms. Lifted, exhaust, voilant intake. The truck has an issue with rough idle and white smoke on startup. Smells like diesel heavy, sounds like its missing a bit. When it warms up it seems to go away, the truck has lots of power all the way through rpms. Deltas are really close, at most I have seen a 13 degree difference very briefly. 4 injectors were replaced at the dealership, and a used computer was put in. (Apparently the edge cs killed it) so I had the dealership flash the pcm, no change. Other issue is that sometimes it takes forever to spool, at least thats what it feels like, dead pedal kind of, hoping the issues are related. Pretty much never can you romp on it and take off, my 7.3 will spin the 37's if I did that. This one is like 2-5 seconds. A process of elimination would be great, do I need to buy a scangauge? Been wanting one for a while now.. Also.. the previous owner claimed there was an egr delete kit in the truck. Not that I seen so I ordered one. Then I find out they welded a washer in the egr cooler?? I should put the kit in or is this ok? thanks for all the help in advance, always got great help with the 7.3.
(Sold) Late 99 f350,cc,lb,4x,auto. Warn hubs, 3" leveling, 4" dual BD with delete & 5" tips, PHP tunes, t500,k&n cold air, Glowshift (fuel,egt,boost,trans temp)
Back,BACK burner: 1964 impala 2dr, convertible, 283, 2spd.:nod:
Daily driver, 2004 f250 6.0, cc, sb, 4x, auto, 4" straight, voilant intake, autometer gauges, egr delete, 03 turbo, hutch mod, looney'd.
BC stroker is offline
post #2 of 17 Old 06-24-2013, 07:43 PM
JustinOOO9's Avatar
Quoted: 524 Post(s)
Garage
Have you changed your fuel filters, both: frame and engine mounted one? You can take off the turbo and clean it, be sure to mark the band clamp for re-assembly though.
Also you can run some biodiesel through the system to clean it and change your filters afterwards. and have you checked your ficm and battery volts?
mine had a no start and the icp/ ipr's were within spec, my ficm sync, and ficm power was good but batteries were at 8.8 v...
make sure icp is at least 500 psi when cranking or no start
ipr make sure its above 15% and under 85% when starting mid 20's normal driving.
check for ficm voltages and sync.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 17 Old 06-24-2013, 08:57 PM Thread Starter
BC stroker's Avatar
Will do the filters when I get home from camp. The batts are brand new and so is the alt.
What is the simplest way to check all my vitals? With scangauge? I take it the band clamp is different from the 7.3 cause I never marked that one, maybe thats why it took an hour to get back on :confused will look at doing the turbo aswell, roughly how many hours should I put aside to remove the turbo snd clean? Pedestal orings in there llike the 7.3? If so, replace them? Thanks alot for the info, I know alot of 6.0 haters and I just bought this thing last week to get it to be a reliable truck to shut them up! I definately love the truck, lots of power, and nothing sounds like a 6.0 in my opinion.
post #4 of 17 Old 06-25-2013, 06:16 AM
AshevilleEngine.com's Avatar
Quoted: 2 Post(s)
Sounds like the one that I have here. I assumed it was a bad injector but no codes. Once I investigated, I found diesel in the degas bottle indicating a cracked head. Once it warms up it runs great. The crack must be small because it's not filling the degas, just adding enough diesel to it to coat the bottle.
AshevilleEngine.com is offline
post #5 of 17 Old 06-25-2013, 06:19 AM
dxusmc's Avatar
Did this happen since you owned it? or right before you bought it? I run a CS in my truck and I've been having some issues getting the thing to start..meaning..it doesn't.
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
post #6 of 17 Old 06-25-2013, 03:53 PM Thread Starter
BC stroker's Avatar
I have definately learned to run custom tunes if you have the means.. if not run stock. You should get rid of the cs, and get it to ford for a reflash. I am in canada and it was only 75 bucks here, so in the states that should only be about 7.99! Seriously though, thats what I would do. The computer in my truck was replaced by the previous owner cause he disconnected the cs while programming. hopefully you can reflash it and get away easy.
post #7 of 17 Old 06-25-2013, 03:55 PM Thread Starter
BC stroker's Avatar
I will definately check it out, thanks. If there is a tiny amount in there any secret to detecting it?
post #8 of 17 Old 06-25-2013, 08:42 PM Thread Starter
BC stroker's Avatar
Ordered the scangauge 2 today, so when it gets here, I will start troubleshooting. In the meantime I will change the fuel filters, and possibly clean the turbo.
post #9 of 17 Old 06-27-2013, 05:47 PM Thread Starter
BC stroker's Avatar
Can anyone tell me if theres a page that lets me know all of the tolerences/voltage ect that the scangauge moniters? I would love to know what to look for that is off. Thanks
post #10 of 17 Old 06-27-2013, 07:57 PM
Powerstroke Techie
JUGERNAUT's Avatar
Quoted: 3 Post(s)
Feedback Score: 13 reviews
Be very very carefull here guys. When just starting a 6.0 and getting white smoke along with a miss. This means a injector is hung open and this can melt a piston real fast.
2001 to 2017 SENIOR MASTER TECHNICIAN
BEEN WITH FORD 31 YEARS:
PROUD NAVY VET= ANTI SUBMARINE WARFARE
A/C ASW A/W WINGS
2003 F250 AND I HATE IT. IT ROBS ME BEFORE I GET TO BANK!
JUGERNAUT is offline
